b16a vtec issues
Old Apr 25, 2010 | 06:01 AM
livetoridee's Avatar
Default b16a vtec issues
So, i bought a b16a swap from a Toronto JDM outfit last year and swapped it into my 91 integra. I bought the jumper conversion harness, and got the car running. At idle, the fan will not kick on. i didnt change any wiring except for adding the vtec, and knock sensor. NOW, when driving, the car wont warm up so that vtec will work. BUT, if im at a stop sign and let the car warm up (fans broken) vtec will then work.
Any suggestions?
Old Apr 25, 2010 | 06:07 AM
fasthatch95's Avatar
Default Re: b16a vtec issues
If theres no thermostat the car will run cool, fix ur fan relays and test 4 some voltage or even run it str8 1st to see if the fan even gots power. Still u dont tell us much!
Old Apr 25, 2010 | 06:19 AM
Where is the thermostat located again? Ive tested the relays and for voltage, the fan works fine it just doesn't kick on when its supposed to. the car is also throwing a code 21 for a Electrical Load Detection. I was thinking bad grounds for that problem, any ideas?
Old Apr 25, 2010 | 06:32 AM
The therm is at ur botom rad hose going into the block ,it will be 2 ten mm bolts and should have some ground wires to it. Once your car reaches warm operating temps the fan should kick on during hot temperatures.
Old Apr 25, 2010 | 06:42 AM
Awsome, thank you much man. Ill check it out today and post results
GsO Redneck
Apr 4, 2012 01:05 PM
deegaw1126
Nov 14, 2011 05:22 AM
Jdm John
14
Jun 19, 2011 04:24 PM
91sifreak
11
Jan 28, 2002 04:08 PM
