!!!!b16a swap problems!!!!
Old Feb 22, 2007 | 11:43 AM
ExodusXIII's Avatar
Default !!!!b16a swap problems!!!!
hi guys i hav a swap b16a in my 91 da integra n for some reason it only spark two cylinder it idles before at like 200 rpm then today it idles fine at 750rpm but would rise up to 1200rpm then drops back down to normal idle then all of a sudden it leak out gas frm my header gasket one of my freind said it could b fuel injector problem or it could b a piston ring..i need some halp anything would that sounds logic id b thankful for thanks
Old Feb 22, 2007 | 11:51 AM
GoldCoin's Avatar
Default Re: !!!!b16a swap problems!!!! (ExodusXIII)
did you put the spark plug wires from the valve cover to the dizzy in the correct order?
Old Feb 22, 2007 | 11:58 AM
ExodusXIII's Avatar
hmmm i think i put it in right order but why only two spark plugs work even after i try changin it i even took out tha spark plugs n start up tha car n it work but idled at 2000rpm so iono wuts goin on.....n it started leakin out of my header gasket today n i notice white smoke too was comin frm the exhuast
Old Feb 22, 2007 | 12:03 PM
GoldCoin's Avatar
Default Re: (ExodusXIII)
white smoke is oil i believe.
Old Feb 22, 2007 | 12:17 PM
ExodusXIII's Avatar
ok when i was drivin it lost alot of power i had to downshift to 3rd or 4th gear jus to go 50 mph n its worst when goin uphill it start to slow down to where i was at 2nd gear flooring it n still no power same as to normal drivin !!!NO POWER!!! why is that?
Old Feb 22, 2007 | 12:38 PM
GoldCoin's Avatar
check compression and leak down
Old Feb 22, 2007 | 08:18 PM
ExodusXIII's Avatar
thanks ill do that this week
Old Feb 24, 2007 | 02:45 PM
ExodusXIII's Avatar
ok i did change in tha spark plug wires but tha same two spark plugs arent sparkin guessin it has something to do wit tha pistons anyone wanna hav n input on this subject?
1988montecarlos
Mar 12, 2014 03:07 PM
pompom
Dec 30, 2006 06:18 PM
200k mile sol
Mar 4, 2006 09:06 PM
92CivicSiR2
Sep 22, 2004 01:30 PM
B2FiNiTY
Aug 19, 2003 01:33 PM
