b16a question
Old May 12, 2006 | 05:09 PM
ViCtOr VaHn's Avatar
Default b16a question
is it nessesary to rebuild your head when blowing a head gasket. Do u have to replace anything besides the gaskets
Old May 12, 2006 | 05:13 PM
CivicSiDriver02's Avatar
Default Re: b16a question (ef9er323)
I would pull it all apart, clean it and take some measurements. Its off the block anyway, you might as well check it. When you blow your head gasket there is always a possibility of engine damage. Coolant is a wonderful thing, but it does not lubricate like oil.
Old May 12, 2006 | 07:14 PM
Default Re: b16a question (CivicSiDriver02)
i was planning on pressure testing it to make sure everything is ok, and if it is just leave it like that.peopl are telling me to resurface it too. thanks for the help
Old May 12, 2006 | 08:32 PM
_Cyclone_'s Avatar
Did you figure out what the reason was for the HG blowing in the first place? It may be relevant...
Old May 13, 2006 | 12:57 PM
i think the timing was way off , because in the morning when the car was cold it would take me 15-20 cranks to get it started
Yobee
16
Jan 13, 2013 11:03 PM
crxb16a90
Feb 24, 2010 04:26 PM
eg6madness
Nov 1, 2007 11:33 AM
Eg6LazyPt
May 18, 2005 08:02 PM
Mattb16teg
Jan 27, 2005 09:07 PM
