B16A Compression test #'s
Old Feb 26, 2010 | 01:28 PM
almostjdmeg's Avatar
Default B16A Compression test #'s
I have a stock B16A bottom end with a gsr head on it and today i did a compression test and got the results below. Do these seem really low to anyone? Why would this be? THanks
Cyl. 1-128 Cyl. 2-130 Cyl. 3-130 Cyl. 4-130
Old Feb 26, 2010 | 01:37 PM
DeLucia's Avatar
Default Re: B16A Compression test #'s
shoulda be around 180 or higher, my 9:1 motor reads 185 across the board. A stock b16 is 10:1 IIRC
Old Feb 26, 2010 | 01:38 PM
95 integra's Avatar
Yes, they are low....could be alot of reasons. Bad rings, timing is off, valves are sealing...etc. For all of them to be low like that, are you sure you did the test properly (warm engine, WOT)?
Old Feb 26, 2010 | 02:05 PM
This is how i did the test, i took all the spark plugs out, screwed the compression tester into one spark plug hole, turned the motor over for 5 revolutions, got out and looked were the gauge was at. On all 4 it was pretty much at 130 and it was set there, not moving at all. Someone please tell me if i am doing this wrong, i really hope that my compression is not really that low. THanks
Old Feb 26, 2010 | 03:06 PM
95 integra's Avatar
Warm engine - Wide Open Throttle (WOT)
If you dont do it like that your numbers will not be accurate.
Old Feb 26, 2010 | 03:20 PM
DeLucia's Avatar
Take injector plugs off also, warm engine, WOT, and you can turn it over more then 5 times
Old Feb 26, 2010 | 07:50 PM
Would the numbers be that much different just because i wasnt at WOT?
Old Feb 26, 2010 | 08:14 PM
GagnarTheUnruly's Avatar
If you aren't at WOT you won't breathe well and I think that would result in a lower # on the test.
Old Feb 27, 2010 | 05:04 PM
95 integra's Avatar
Yes, wot makes a big difference, thus the reason I keep telling u this
Old Feb 27, 2010 | 06:48 PM
Alright, thanks, i will try again when i have someone to help, thanks
ricanxplaya
Jan 7, 2014 05:19 AM
bossm
10
Jun 29, 2009 06:52 PM
celestialcivic91
Jan 23, 2007 03:12 PM
gamakichi77
Dec 22, 2004 06:56 PM
y_design
Jul 13, 2004 12:39 PM
