B16 problems help!!
Old Sep 21, 2007 | 07:00 PM
juanintec's Avatar
Default B16 problems help!!
ok so i got a b16 on my integra...
its runs a little bad. so i took each spark plug wire at a time to see if it would change. engine speed changed when i took 3 off at a time but it did nothing when i took one of them off.
like if i was running on 3 cylinders like i have no compression on one cylinder.
i did a compression test and the numbers were good. i had 195 200 185 185
and did not really change with a wet compression test(adding oil)
like the compression is good right??
i changed the spark plugs and it does the same and i switch the wires from my other DA and it does the same thing...
the fuel pressure regulator readings are good so im getting fuel and everything and it sparks just fine
what is the problem if i have compression and spark and fuel????
what else can be the problem
Old Sep 21, 2007 | 10:45 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: B16 problems help!! (juanintec)
maybe the distributor? Do you have the firing order correct?
Old Sep 22, 2007 | 12:23 AM
B18CivicHatch's Avatar
Default Re: B16 problems help!! (B serious)
the only other thing i can think of that might be is that maybe the plug itself isnt sparking cuz i told ya everything i did to fix my car when i had the same problem the only difference is that i had one cylinder at 60 psi but check all the plugs and make sure they're sparking also try taking the plug out of that cylinder and turning the car over for a few second it should turn on and you should smell gas coming out of the hole if you don't then its an injector or a blockage somewhere
Old Sep 22, 2007 | 12:55 AM
XSIintegra's Avatar
Default Re: B16 problems help!! (B18CivicHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by juanintec &raquo;</TD></TR><TR><TD CLASS="quote">its runs a little bad.</TD></TR></TABLE>
What does that mean? It shakes a lot? sounds bad? loops idle?
Old Sep 22, 2007 | 06:35 PM
juanintec's Avatar
Default Re: B16 problems help!! (XSIintegra)
it shakes a little.
and im running on 3 cylinders.
the saprk plugs are good cuz i switch them aroud to see it the problem would change to a diffrent cylinder but it didnt. it stay at the same one and ran the same....
im going to check that thing to see if i smell gas out of it. if not its an injector right??
Old Sep 22, 2007 | 06:39 PM
gsrob's Avatar
If one's not getting fuel that sounds about right. Could definately be a bad injector.
Old Sep 23, 2007 | 11:18 PM
yea i mean the only thing i can think of it that maybe an injector is just bad if you take the plug out and smell gas then im stumped bro
Old Sep 24, 2007 | 09:04 PM
juanintec's Avatar
yeah im going to check it on thursday
cuz im way too busy.
so ill update on thursday
Old Sep 24, 2007 | 09:17 PM
posHonda's Avatar
i just have to ask...
why a b16?
Old Sep 24, 2007 | 09:58 PM
B serious's Avatar
Default Re: (iVteC_PoWeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iVteC_PoWeR &raquo;</TD></TR><TR><TD CLASS="quote">i just have to ask...
why a b16?</TD></TR></TABLE>
because they're awesome. I'm swapping one into my S2000.
andrew__g
Apr 1, 2009 11:11 AM
triple
Jun 18, 2006 08:14 PM
Maroonda9
Jun 26, 2005 08:47 AM
zracer240
Apr 24, 2005 08:35 AM
Goldfingiz
Aug 24, 2003 05:53 PM
