b16 Distributor same as b18a?
Old Nov 7, 2006 | 12:24 PM
bennyDA's Avatar
Default b16 Distributor same as b18a?
Just as the title says..
Simple question needs a simple answer search wont work for me says page cannot be loaded sorry
Does anyone have any pics of doin b16 dizzy on b18...??
Also how do u take off the entire dizzy? i know the 3 bolts, but what tool would u use to get at that bolt on the top? uvj joint socket thing? im thinkn? but i dont have one ill go buy one if necessary, and a wrench wouldnt do it, wayyy to torqued
Modified by bennyDA at 8:45 PM 11/16/2006
Old Nov 7, 2006 | 12:44 PM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: b16 Distributor same as b18a? (bennyDA)
internals are the same as are the plugs but you will not be able to mount it without chopping off one of the mounting ends (ghetto)
Old Nov 7, 2006 | 02:23 PM
bennyDA's Avatar
Default Re: b16 Distributor same as b18a? (GRAF-FITI)
bogus lol
nvm then
thanks
Old Nov 16, 2006 | 07:46 PM
bennyDA's Avatar
I still need help, integra's been dead for a week when i have a b16 dizzy in my room, i gtg get that on. just need some help please fella's
Old Nov 17, 2006 | 12:55 AM
dannylDAsport's Avatar
swap all the internals from b16 to the b18 housing
Old Nov 17, 2006 | 07:11 AM
bennyDA's Avatar
Default Re: b16 Distributor same as b18a? (dannylDAsport)
the b16 has a different ignitor.. same thing actually but i mean the heat shield thing where it bolts do not match up, b18 is on bottom, b16 is on the side the screw holes...
Old Nov 17, 2006 | 08:03 AM
95 integra's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bennyDA &raquo;</TD></TR><TR><TD CLASS="quote">
They are different, they have a different bolt pattern and depending on the year(s) the internals and plugs are also slightly different. Not sure wtf else you want to hear.....buy a new distributor for your car and be done with it.
To take the dizzy off, you take the 3 bolts loose, unclip the wiring harness and take the plug wires off. Pretty straight foward if you ask me. A closed end wrench should do the job just fine....."its too torqued" means you need to grow a set and put some muscle into it....and/or get a big hammer.
Old Nov 17, 2006 | 04:31 PM
bennyDA's Avatar
Default Re: b16 Distributor same as b18a? (95 integra)
well thanks for the attitude dick...
maybe i dont have enough money for a new distributor..?!?!?
si90rex
Mar 5, 2007 06:05 PM
keepitngga1
Jan 31, 2007 03:36 PM
high_revs
Nov 9, 2005 02:13 PM
