B15C???
Old Jul 30, 2008 | 11:00 AM
Circusraven's Avatar
Default B15C???
Wikipedia says this is a Honda VTEC engine, but I'd never heard of it before today. Does anyone know what car it came in? and what country?
Old Jul 30, 2008 | 01:07 PM
THEefhatch1's Avatar
Civic Wagon Type R
Old Jul 30, 2008 | 02:12 PM
hotrod99's Avatar
Default Re: (THEefhatch1)
they were used in the 99-02 Honda City
Old Jul 30, 2008 | 04:46 PM
Default Re: (hotrod99)
Do you guys know if it looks like a standard B-series Vtec engine?
Old Jul 30, 2008 | 05:00 PM
hotrod99's Avatar
Default Re: (Circusraven)
I think they are single cams and look like a d16
Old May 13, 2012 | 02:02 PM
Nitrous1024's Avatar
Default Re: B15C???
What's the power output on one of these, and how does it compare to the D15B?
I have a D15B, but I was wondering if it's a worthy swap.
Old May 13, 2012 | 03:48 PM
NemesisCBR's Avatar
Default Re: B15C???
i dont see any info about it anywhere including wikipedia so youd have to post a link for any comments regarding that. If it were a b15 then it would be dual overhead cams not single as the B or D in the code suggests.
Old May 13, 2012 | 04:02 PM
Default Re: B15C???
B15A
1.5L SOHC I4 16V non-VTEC PGM-FI
96-99 Honda City LXi / EXi
100 hp @ 6500 rpm
95 lb-ft @ 4600 rpm
B15B
99-02 Honda City
105 hp @ 6400 rpm
100 lb-ft @ 4600 rpm
B15C
1.5L SOHC I4 16V VTEC PGM-FI
99-02 Honda City
115 hp @ 6800 rpm
103 lb-ft @ 4600 rpm
Taken from here: https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/b15-can-pass-will-fail-2380919/
Old May 13, 2012 | 04:04 PM
Default Re: B15C???
From one photo that I've seen so far, the engine is transversely turned the other way around (so the transmission is on the right hand side of the vehicle).
Old May 13, 2012 | 04:31 PM
Ryan96GSR's Avatar
Default Re: B15C???
10hp difference between the non vtec model?
I do not see the point if that is the case.
Old May 13, 2012 | 05:45 PM
luvmihatch's Avatar
Default Re: B15C???
Ive seen more unicorns then this.
JK.
These are every where in Europe. Just like the B18c2, 3, 4, and 6
Just different models for diff lands.
Old May 13, 2012 | 05:48 PM
ants4g63's Avatar
Default Re: B15C???
wow i always learning new stuff
Old May 14, 2012 | 01:13 AM
standy xsi's Avatar
Default Re: B15C???
that 99-02 honda "city" is called domani here
bit of info
guysensei
68
Dec 5, 2012 10:41 AM
jasperjohn
Oct 27, 2008 09:55 AM
jdmCD695
Jul 7, 2008 03:45 PM
ukvtec
Sep 30, 2004 11:51 AM
Fooman
Jan 7, 2002 12:51 PM
