axle question,..
Old Sep 12, 2007 | 04:16 PM
hspoon's Avatar
Default axle question,..
can the teeth of an halfshaft go bad that wont let the axle all the way in.... in a dc???
Old Sep 12, 2007 | 04:37 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: axle question,.. (hspoon)
Have you visually inspected the teeth for damage or burrs?
Old Sep 12, 2007 | 07:50 PM
hspoon's Avatar
Default Re: axle question,.. (Dogginator)
well it messed up my the teeth of my axle... cant see the teeth on the half shaft
Old Sep 13, 2007 | 02:26 AM
1992Si's Avatar
The splines should not go bad by themselfs. Something had to happen to cause abnormal wear or movement in the axle.
Same with the splines on the hub end. I just went through two rebuild axles until I found one that would work.
shadohconspiracy
Nov 3, 2007 02:22 PM
vha27
Nov 17, 2003 07:27 PM
92sleepR
Mar 21, 2003 12:40 PM
philipkrotch
Jan 22, 2003 10:46 AM
