Automatic versus Standard
Performace wise how do automatics suffer versus standards? And please could someone give me specific data I.E. stock 0-60 times for the two etc. I Currently drive a '98 integra LS automatic... if someone could give me times for that car specifically and some comparison times say a some year model standard it would be a good help. I am debating whether or not to save up for modifications for my car, and if an automatic is terribly slower than a standard i might just say screw it because integra still look nice stock and i could save for something else. Any help is appreciated thanks.
Ballpark... stock auto has a 0-60 of 2.6-2.5 with powerbraking NOT neutral dropping...... stick can be 2.1 with a good driver and descent tires...
These are estimates..
2.1seconds 0-60??? hayabusa auto??? lol, auto hondas hurt man, i think there is a guy on this board with a charged automatic ls, he pulls high 13s but he's also went through 3 trannies i believe???
[Modified by NemesisGSR, 8:44 AM 6/25/2002]
I believe it can range anywhere from 0.5-1.0 sec. in the 1/4 mile for LS's... Honda Auto's suck donkey *****... I know, I drive one to work everyday...
Auto's are generally 0.5 second slower from 0-60 and in the 1/4 mile as compared to their 5 spd counterparts.
Vu: No I didn't get a chance yet, waiting for a fuel rail, and bigger injectors and gonna hit up a dyno for serious fuel system tuning before I go again
Okay, so i guess it is possible to make an automatic fast. How much wear on the engine in an automatic happens when you "gun" it. How bout if you shift it is that worse?
there is nothing wrong with him downshifting and flooring the auto .. its not gonna hurt the tranny .. the ecu has shift points and fuel cutoffs to protect it
and there is a benifit ... if your in the right RPM range/gear.. downshift and floor it ... you get the power at that exact moment .. insted of waiting an extra second for the ECU to downshift for you ...however i have not found a benifit of shifting gears from the line ... i would do what shadowdawn said .. leave it in D3
we have all had this discussion before ... if you know someone's tranny that got screwed .. then the dood was doing neutral drops .. or his auto tranny was fragged .. or on the verge to begin with ... i play with shifting my auto every day for the past 2 years and i drive my honda hard.... no tranny probzz here 129k
Interesting, quite interesting...I learned a bit about autos in this thread. I have an auto. I think power braking does help. I did that and it helped launch my car really well. It actually made me spin tires, but just for like 1/2 sec. Anyone been able to chirp gears? I've only done this once while manual shifting up 1-2-d3-d4. Later.
contrary to popular ricer belief, you DO NOT want to chirp gears..it's not "manly" and it doesnt mean you have more power, it usually just means you can't shift.
lol, anyways, one other thing should be noted- launch on "1" instead of "D3". The auto tranny almost "hesitates" when you launch in D3..try it out some time!!
when i had my 15" gsrzz i could chirp droppin, at the right RPM, from 2->1 and chirp again going back from 1->2
i cant chirp **** with my 17z ..then again i got brand new tread too (:
as for 3rd hesitating ?/ hmmm havent noticed it ... but i can tell you .. for example .. just leaving it in D4 ... when you are stopped and in its actually
in 1st gear ... and you take off with it floored...it goes all the way to redline/shiftpoint and shifts gears EXCEPT 3rd->4th soo really i havent seen a benifit with starting out in 1st and manually shifting up
but hey .. ill play with it any way you ask ... just make some recommendations and ill try it ... ill test the 3rd gear in my ride VS 1st .. and tell ya what i get
See. this is the EXACT reason I got screwd on my 1/4 cause I was in D4 and 4rd shifted WAY before redline and I ended a good 100 feet or more of the quarter in 4th gear...... sucked and killed my first times
im definately gonna have to remember this when i go to the track for times
Anyone have figures of their stock 1/4mi.? I would be happy to just hit mid 16's in my auto SE. hehe
DBG0823
10
Feb 6, 2009 09:03 AM
