automatic ls vtec
Old Nov 1, 2007 | 11:56 AM
GsTurbo98's Avatar
Default automatic ls vtec
is it possible going ls vtec with a automatic tranny? I couldnt find this answer in the archives or on google. Do i have to change the ecu? And what else?
Old Nov 1, 2007 | 11:59 AM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: automatic ls vtec (GsTurbo98)
but yes, my son, it IS possible...but POINTLESS
Old Nov 1, 2007 | 01:56 PM
GSR in progress 96's Avatar
* B A N N E D *
its possible but I don't think it would be worth it
Old Nov 1, 2007 | 03:14 PM
princefredo's Avatar
you need the ecu from the auto sirg from japan. its a gsr engine with an auto ls tranny.
Old Nov 1, 2007 | 03:39 PM
Padawan's Avatar
Darth ModerVader
Let's try again.
Yes, it can be done, but it won't be as straightforward as a manual. Is there a reason you want the auto?
Old Nov 1, 2007 | 05:44 PM
ND40oz's Avatar
Default Re: automatic ls vtec (Padawan)
probably be cheaper/easier just to buy the whole auto sir-g swap
Old Nov 1, 2007 | 05:50 PM
PACT man's Avatar
Default Re: automatic ls vtec (ND40oz)
There was a post about this awhile ago, and they were saying that instead of trying to find the impossible being the SIR-G auto ECU is to just run a completely chipped auto computer to add in the VTEC and remove rev limiter and such.
Old May 20, 2008 | 06:09 PM
Mobgoblin's Avatar
Default Re: automatic ls vtec (PACT man)
This should help
http://www.sportcompactcarweb.....html
http://hondaswap.com/general-t...32829/
Theres everything you need to know
Old May 20, 2008 | 11:29 PM
inspiration's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GsTurbo98 &raquo;</TD></TR><TR><TD CLASS="quote">is it possible going ls vtec with a automatic tranny? I couldnt find this answer in the archives or on google. Do i have to change the ecu? And what else?</TD></TR></TABLE>
It's possible. You can either use a auto p28, auto jdm p30, auto jdm p72. Alot of them have the sport button on them. Some jdm auto's come with LSD.
A person can build a automatic car to beat any manual car and plus you get a perfect launch every single time. Different stages of torque converter, shift solenoids, and transmission control module can make it more better.
Old May 21, 2008 | 03:00 AM
PEACEeasy's Avatar
why automatic? =[
Old May 21, 2008 | 11:17 AM
Mcdc2's Avatar
Default Re: automatic ls vtec (GSR in progress 96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR in progress 96 &raquo;</TD></TR><TR><TD CLASS="quote">its possible but I don't think it would be worth it</TD></TR></TABLE>
Old May 21, 2008 | 11:33 AM
superdat1's Avatar
why resurrect an old thread?
Old May 21, 2008 | 12:05 PM
PHAT-INTEGRA's Avatar
Default Re:
I'm in the middle of doing it. It can be done but you need to find a JDM SIR-G ECU and good luck and finding one (took me 2 years to hunt down) or your second option is to piggy back the V-AFC to your stock ECU that will controll the VTEC from the V-AFC some1 over Team-Integra did that.
Mine will be done by September. Just need to get some minor things like ITR T-Belt, ITR waterpump, adj Cams gears, JDM ITR camshaft, ARP cams cap bolts, ARP studs, Valve cover mine is lost some where , B16 IM or Skunk2 IM. Then It should be ready to swap.
Modified by PHAT-INTEGRA at 4:11 PM 5/21/2008
Modified by PHAT-INTEGRA at 4:12 PM 5/21/2008
X_evolution
Aug 14, 2009 12:29 PM
gwegcivic
Oct 20, 2005 09:57 PM
Liquid Ice NF
Sep 1, 2005 02:38 PM
shinji666
Aug 23, 2004 08:06 AM
X-Scott
Aug 12, 2001 11:29 AM
