Automatic Gear Box Overdrive problems
Old Nov 29, 2005 | 10:55 AM
stefanne3's Avatar
Default Automatic Gear Box Overdrive problems
I have an automatic '99 LS that seems to be a little temperamental when it comes to shifting into overdrive.
I let the engine warm up before hand (enough for the RPM's to go down where they should be - anywhere from 1 min in the summer to 5-6 in the winter). But it seems like no matter what I do, it will not use the overdrive unless it's been driven for a while.
For a while I thought that it needs a little more ... weight to shift into overdrive. Every time when going to work for a good while, it was shifting into overdrive when going up a little bit of an incline on the highway. The same spot every time.
Then this changed though and now, i drive the car same 15 minutes to work every morning and i get there without the overdrive ever being used.
So my question is really: how does it decide to shift into overdrive? what's the mechanism that does this - could that be malfunctioning? Is there something i would want to look into replacing in order to make the overdrive shift happen all or most of the time?
I should mention couple things: after driving it for a while ... say after 1 h on the highway it's definitely using the overdrive then. Even though the weirdest thing started occuring: after about 5hrs of continuos driving, we stop for gas, turn the engine off and then when started back up and get on the highway - same thing, won't engage the overdrive.
I also had a carburated '88 Accord before, and i had essentially the same problem. Could it be a Honda issue that i'm not aware of?
Thanks much
bansell
Transmission & Drivetrain
Dec 30, 2017 11:41 AM
ExtraBlackRex
Sep 17, 2011 06:40 PM
96blackaccordv6
Jul 10, 2007 07:21 PM
xunkn0vvnx
Oct 12, 2004 09:46 AM
