automatic climate control
Old Oct 12, 2001 | 07:52 PM
mercury's Avatar
New User
Default automatic climate control
Did the G3 Integras ever come with automatic climate control in any country? How about an aftermarket version?
Old Oct 12, 2001 | 08:06 PM
mitch99's Avatar
New User
Default Re: automatic climate control (mercury)
well i dont know anything about any integra's coming from the factory with automatic climate control. but it probably wouldnt be too hard to make it yourself. id imagine all it would take is a thermistor, some basic circutry, and a relay. you would put the relay on the common wire on the fan speed contol switch. i assume cutting power to that switch would also disengage the compressor. if it dosnt disengage the compressor, you might run into problems with the condenser icing over without the fan blowing air over it. you probably wouldnt be able to change the temperature very easilly though.
CivicKiller123
Honda Civic (2001 - 2005)
Sep 12, 2013 11:24 AM
bjgill333
May 27, 2013 07:57 AM
phistahh
Dec 16, 2008 01:27 PM
2k1_ITR_0736
Jun 19, 2003 02:00 PM
