arp head studs
Old Aug 17, 2004 | 11:16 AM
skunk2eg's Avatar
Default arp head studs
after you remove the head aren't you suppode to replace the head suds? ive heard arp are really good. anyone used these before?
Old Aug 17, 2004 | 11:20 AM
Will_H's Avatar
Default Re: arp head studs (skunk2eg)
yes you should replace them. ARP is one the best. You cant retorque the OEM honda head bolts once they are taken off.
Old Aug 18, 2004 | 01:20 PM
B00ST2nR's Avatar
ARP head studs
You can't go wrong with it.
Old Aug 18, 2004 | 10:20 PM
GoHonda91's Avatar
i heard that u dont really need to get a new set with these aftermarket studs, but im not 100% sure...im using AEBS.
Old Aug 18, 2004 | 10:40 PM
3.504's Avatar
Default Re: arp head studs (GoHonda91)
ARP's you dont have to replace. the OEM hondas you do. either way you go, listen to the torque specs givin by the stud/bolt manufacturer. so if you go with honda, use honda torque specs. going with arp, use they're specs.
Old Aug 19, 2004 | 09:38 AM
X-Mazda 3 Racer's Avatar
Default Re: arp head studs (3.504)
I like the Golden Eagle Mfg. " HD " head studs
http://www.goldeneaglemfg.com
Old Aug 19, 2004 | 09:46 AM
LOSERboy's Avatar
I've had some friends re-torque oem honda studs and they haven't had a problem YET!
Its not something I'd recommend but it can be an option if you're cheap
I'd take the extra precaution and spend $100 buying arp head studs. You can't go wrong with them....
Old Aug 19, 2004 | 11:27 AM
skunk2eg's Avatar
Default Re: arp head studs (LOSERboy)
thanks for the info
Old Aug 19, 2004 | 11:49 AM
cutter00's Avatar
APR headstuds will be the ONLY aftermarket headstud i use.
Old Aug 19, 2004 | 03:42 PM
shivic's Avatar
Default Re: arp head studs (WillisGS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WillisGS &raquo;</TD></TR><TR><TD CLASS="quote">yes you should replace them. ARP is one the best. You cant retorque the OEM honda head bolts once they are taken off.</TD></TR></TABLE>
ive reused oem headbolts many times. If your on a budget, fudge it.
scspeed
12
Dec 22, 2008 08:23 PM
Mike95lude
Aug 27, 2007 07:39 PM
LsVtakYO
Dec 24, 2005 06:53 PM
dumpeDc2
Nov 4, 2004 08:07 AM
yellowturbo
Mar 11, 2004 10:14 AM
