A arm problems should this be cause for concern?
Old Jan 29, 2006 | 10:59 AM
Solscud007's Avatar
Default A arm problems should this be cause for concern?
http://www.team-integra.net/fo...age=1
Cick on the link for the pics. I tok my rims off and saw this on my passenger side. can i jsut hammer it back down? what is that piece exactly? what would cause this to happen?
Old Jan 29, 2006 | 11:06 AM
Lauj87's Avatar
those are your stock cambers....you can just hammer them back down....well if your car is lowered past 1.5 inch i think you should get new ones while your at it..save you some tread life on your tires.
Old Jan 29, 2006 | 12:14 PM
Racermech's Avatar
Default Re: (Lauj87)
Looks like the shock has more travel than the a arm will allow, it looks like they are bottoming out, but the shock still has travel causing it to push the ball joint out. Add a bump stop and press the ball joint back in.
Also cabmer is not the only cause of tire wear, toe is. Plenty of people here are very low, with no camber kit, but there toe is set back to factory specs.
DK SkeeS_EF
15
May 24, 2012 05:10 AM
civicSF98
Jul 5, 2010 09:46 AM
TurboLaxx
Suspension & Brakes
Dec 1, 2005 04:07 AM
G2integra217
10
Jul 20, 2005 04:49 PM
