Anyone have problems with DA's?
Old Nov 24, 2003 | 05:34 AM
HRDCORD's Avatar
Default Anyone have problems with DA's?
I'm thinking about buying a 1992-1993 Integra LS or RS and swapping a B18, however I don't know all that much about them. Has anyone had any problems with them or does anyone have any information/advice about them that I should know before I think any further?
Old Nov 24, 2003 | 05:42 AM
Gabe_'s Avatar
Default Re: Anyone have problems with DA's? (HRDCORD)
I have one with a JDM B18C in it... and no real problems, other than it being heavy. 111,000 miles on the chasis.
Old Nov 24, 2003 | 05:52 AM
Muckman's Avatar
Moderator in Chief
I have a 91 LS for my beater. Its pretty good to work on. Plenty of parts for it in junkyards etc. I think its kind of ugly but it works!
Old Nov 24, 2003 | 06:42 AM
OVERBOOST TEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HRDCORD &raquo;</TD></TR><TR><TD CLASS="quote">I'm thinking about buying a 1992-1993 Integra LS or RS and swapping a B18, however I don't know all that much about them. Has anyone had any problems with them or does anyone have any information/advice about them that I should know before I think any further? </TD></TR></TABLE>
Its ok, the only problem i have encountered has to do w/ my fuel system, but i have not even tuned the car yet. If you are not boosting the care right away you should not have a problem.
Old Nov 24, 2003 | 06:55 AM
LODOSS's Avatar
Default Re: Anyone have problems with DA's? (Muckman)
!! DAs are one of the best looking cars and also JDM ITR's.
Old Nov 24, 2003 | 07:25 AM
HRDCORD's Avatar
Sounds pretty good so far.... Keep it comin guys!
Old Nov 24, 2003 | 07:29 AM
brownshigh's Avatar
i have owned 2 da integras and the only problem i have had was with the heat.the blower motors kept goin out
Old Nov 24, 2003 | 08:52 AM
TEXN3's Avatar
Default Re: (brownshigh)
1990 DA. only problems was a cracked radiator, brake master cylinder, dented oil pan, rear camber issues on stock wheels, bearings seized because a pulley was over-torqued, automatic sensor in the cold and an axle replacement. all of those are due to age, nothing of a manufacture defect.
you may want to check out http://www.g2ic.com
it is a bit more informative on the DA/DB integra's.
Old Nov 24, 2003 | 10:59 AM
Wraith_G2IC's Avatar
The 90-93 came with B18s. Like B18A1 for 90-91 LS/RS/GS and B18A2 for 92-93 LS/RS/GS. A B18C1/5 can be swapped right in with very little effort. If you want race it the RS is usually the lighter of the group. Less options.
My only real annoying problem is the vent control buttons don't stay lit all the time. But with some of the info at http://www.G2IC.com, and here at HT you can fix almost any DA pain.
Old Nov 24, 2003 | 11:10 AM
mr.beeks's Avatar
Default Re: Anyone have problems with DA's? (Wraith_G2IC)
I own 3 of them and they are all easy fixes.
Old Nov 24, 2003 | 08:22 PM
HRDCORD's Avatar
Yeah I was planning on an OBD1 B18C or if moey goes the right way I might go LS-Turbo.....
Old Nov 24, 2003 | 08:40 PM
FlaN.'s Avatar
only problem i used to have to my DA (r.i.p.) was the IACV was always botched up and my car used to stall at lights and ****. but since you're swapping, i guess that's irrelevant.
Old Nov 25, 2003 | 06:40 AM
Muckman's Avatar
Moderator in Chief
Default Re: Anyone have problems with DA's? (LODOSS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LODOSS &raquo;</TD></TR><TR><TD CLASS="quote">!! DAs are one of the best looking cars </TD></TR></TABLE>
lol no way! look at my pile.
Def wont be picking up any chicks in this. Check out the 9 inch wheel gap im pimpin'
Old Nov 25, 2003 | 06:51 AM
JDMHN8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wraith_G2IC &raquo;</TD></TR><TR><TD CLASS="quote">The 90-93 came with B18s. Like B18A1 for 90-91 LS/RS/GS and B18A2 for 92-93 LS/RS/GS. A B18C1/5 can be swapped right in with very little effort. If you want race it the RS is usually the lighter of the group. Less options.</TD></TR></TABLE>
No. All 1990-93 Integras came with a B18A1. 1990-91 vehicles were Non-OBD and had 130HP, while 1992-93 cars were OBDI and had 140HP.
I've yet to have a major problem with my car, other than a leaky oil pan gasket and an axle replacement. DAs look WAY better than USDM DCs (other than the R), but dedicated aftermarket support isn't as plentiful.
Old Nov 25, 2003 | 07:08 AM
DoctorGSR's Avatar
u also might want to be prepared to change the main relay. thats the only prob i have had with my car. besides blowin up the b18a
Old Nov 25, 2003 | 09:53 AM
Default Re: Anyone have problems with DA's? (JDMDA9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMDA9 &raquo;</TD></TR><TR><TD CLASS="quote">
No. All 1990-93 Integras came with a B18A1.</TD></TR></TABLE>
Brain Fart! Yea the OBD and 10hp was the biggest difference. I don't know why I was thinking A2. Doh!
I guess the only exception was the USDM 92-93 GS-R B17A1. Not including the JDM 90-93 that could come with B16s and rumor has it there are DAs in NZ that have some little D series motors too.
Old Nov 25, 2003 | 10:27 AM
8Grand's Avatar
I like my tan leather, I just need to fix my damn cooling system... sorta took out my rad in a accident.
Other then that a good daily beater for me while I build my CRX.
Old Nov 25, 2003 | 11:51 AM
Gabe_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wraith_G2IC &raquo;</TD></TR><TR><TD CLASS="quote">If you want race it the RS is usually the lighter of the group. Less options.</TD></TR></TABLE>
I agree. I wish I wouldn't have wasted my time buying a GS-R. I have since gotten rid of the b17 it came with, and pretty much gotten rid of every comfort option that makes it a GSR. Basically, it is a lot easier to start out with an RS, than to turn your GSR, into an RS.
Old Nov 25, 2003 | 01:54 PM
2muchGT's Avatar
I've yet to have a major problem with my car, other than a leaky oil pan gasket and an axle replacement. DAs look WAY better than USDM DCs (other than the R), but dedicated aftermarket support isn't as plentiful.</TD></TR></TABLE>
i loved my DA. only problem was with master cylander(sp) but thats just because i let a friend drive it...long story.
btw, not sure about the other models but i know the 92-93 RS's had b16's, not b18's
Old Nov 25, 2003 | 02:16 PM
Eviloliv3's Avatar
i love my DA as well. my only problem is piston rings in 3rd cylinder are bad, i eat oil like its cookies, and im starting to get pudgy...
all the other problems ive had are minor, or were caused by me (lights shorting out cause of wire job)
i repeat, great car. definitly a good buy
Old Nov 25, 2003 | 04:17 PM
VtecDA9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LODOSS &raquo;</TD></TR><TR><TD CLASS="quote">!! DAs are one of the best looking cars and also JDM ITR's. </TD></TR></TABLE>
Agreed, here's a pix of mine
12:1 ls/vtec doesn't hurt either
Old Nov 25, 2003 | 04:21 PM
Eviloliv3's Avatar
[homer] MMMM DA9 MMMMM [/homer]
Old Nov 25, 2003 | 04:38 PM
riceball777's Avatar
yes i had problems with my DA
https://honda-tech.com/zerothread?id=656494
i blew the motor
over the 2 years that i had my DA i have gone through]
3 axcles a trannie, clutch, and a bunch of other lil stuff
but hey the car is 13 years old has like 250-300k on the chasis
Old Nov 26, 2003 | 09:40 AM
chsamia's Avatar
Default Re: Anyone have problems with DA's? (VtecDA9)
I totally agree about DA's are one of the best looking cars out there. I just got mine back in May after totalling my 01 R
Old Nov 26, 2003 | 09:59 AM
SpoolnG2's Avatar
Default Re: Anyone have problems with DA's? (chsamia)
Kick *** Car .
Heres mine if u wanna check it out https://honda-tech.com/zerothread?id=621463 Just scroll down a little, its the black one.
