anyone else have the problem with the passenger side window rolling down?
Old Dec 13, 2001 | 07:28 PM
acuracer's Avatar
Default anyone else have the problem with the passenger side window rolling down?
my power passenger side window doesn't roll all the way down, unless you push it down. sum insight please!
Old Dec 13, 2001 | 07:34 PM
Blue teg's Avatar
Default Re: anyone else have the problem with the passenger side window rolling down? (acuracer)
it happens to me whenever raining....dunno why
Old Dec 13, 2001 | 09:32 PM
bikeboy80's Avatar
Default Re: anyone else have the problem with the passenger side window rolling down? (Blue teg)
mine actually sticks more when its dry, when its raining it goes right down
Old Dec 13, 2001 | 09:41 PM
eracer325's Avatar
Default Re: anyone else have the problem with the passenger side window rolling down? (bikeboy80)
spray some w40!!! it works!!! it happened to me & my girl too~ for driver side tho~
Old Dec 13, 2001 | 11:07 PM
SuperSteve's Avatar
New User
25 Year Member
Default Re: anyone else have the problem with the passenger side window rolling down? (eracer325)
Yeah what he said, and if you can take off your door panal and make sure that the motor is tight.
Old Dec 13, 2001 | 11:55 PM
SamuraiJack's Avatar
Default Re: anyone else have the problem with the passenger side window rolling down? (SuperSteve)
mine goes down..but it takes twice as long as the driver side window
Old Dec 14, 2001 | 08:24 AM
tonydatyga's Avatar
some ghetto ****... **** it and replace w/ lexan if it doesnt open anyways
Old Dec 14, 2001 | 08:26 AM
MRXMUFFIN's Avatar
yup some wd40 should do the trick
Old Dec 14, 2001 | 10:17 AM
Tail Happy's Avatar
This is a known problem with Integras. I believe there is a Technical Service Bulletin out for this. Take it into the dealer..you should be able to get it fixed for free.
Chris
Old Dec 14, 2001 | 01:08 PM
crazyteg's Avatar
Default Re: anyone else have the problem with the passenger side window rolling down? (SamuraiJack)
so true, my passengerside door window is sooo slow!
Old Dec 14, 2001 | 01:18 PM
acuracer's Avatar
Default Re: anyone else have the problem with the passenger side window rolling down? (nightcrawler808)
where should i spray the WD40?
Old Dec 14, 2001 | 02:16 PM
eracer325's Avatar
1. roll down your window
2. spray some wd-40 on the black weatherstrip all around the window
3. roll your window glass up and down a few times
if the problem not solve yet~
4. remove your door panel
5. spray some wd-40 again on the window glass equalizer arm
the problem still exist ?
6. check with your window motor and regulator
if you need to replace your window motor or regulator then
7. i have one on ebay http://cgi.ebay.com/ebaymotors/aw-cg...ndexURL=0&rd=1
Old Dec 14, 2001 | 02:25 PM
acuracer's Avatar
thanks for your help...
Old Dec 14, 2001 | 02:28 PM
b18bvudoo's Avatar
New User
just take the door panel off and check to be sure. i found out on my passenger side window that part of the window was outside of the rubber guides when going up...dont know how that happened but after i fixed it, it goes up/down a lot faster than my driver's side window. oh i also lubed it up a bit w/ wd40.
Old Dec 16, 2001 | 10:26 AM
ACIN's Avatar
Default Re: anyone else have the problem with the passenger side window rolling down? (vudoo666)
Same problem. It's the rubber guide down in the door panel. Mine is torn. The window gets stuck when in goes down into this rubber guide. I'm going to replace the rubber guide eventually. I put some light oil down the rubber guides and it works for a day or two, but then it's back to getting stuck.
[Modified by ACIN, 11:27 AM 12/16/2001]
Old Dec 16, 2001 | 12:44 PM
acuracer's Avatar
Default Re: anyone else have the problem with the passenger side window rolling down? (ACIN)
its hella annoying when you got friends in the car.
Old Dec 16, 2001 | 12:45 PM
acuracer's Avatar
hey ACIN.. what does your ls hit in the 1/4?
and how to you take the rubber guide out?
thanks.
Slammed_am
Nov 14, 2005 11:29 AM
dk127
Sep 9, 2003 07:03 PM
Phoenix Yellow R
Jan 17, 2003 05:24 AM
