Any negative effects of using oversized filter??
Old Oct 24, 2002 | 06:42 AM
Dan GSR's Avatar
Default Any negative effects of using oversized filter??
I'm considering using the Mobil 1 M105 filter....any harm from this??
Old Oct 24, 2002 | 08:26 PM
Dan GSR's Avatar
Default Re: Any negative effects of using oversized filter?? (Dan GSR)
bump
Old Oct 24, 2002 | 08:30 PM
Kelvin96GSR's Avatar
25 Year Member
what's the point of using an oversized filter? Do you think that you'll benefit from it? I don't see what's wrong with OEM.
Old Oct 24, 2002 | 08:49 PM
Dan GSR's Avatar
Default Re: Any negative effects of using oversized filter?? (Kelvin96GSR)
well obviously it keeps your oil cooler....and from what i understand....your supposed to get better oil pressure...cuz less restriction.....I just switched to one.....we'll see if there is a difference??
Old Oct 24, 2002 | 08:53 PM
FORCED FED TEG's Avatar
New User
I've used one for about a year now. It holds a little more oil and supose to run cooler.
Old Oct 24, 2002 | 08:59 PM
Mr. Softee's Avatar
Default Re: Any negative effects of using oversized filter?? (FORCED FED TEG)
none.
Old Oct 24, 2002 | 09:00 PM
Dan GSR's Avatar
which do you use? mobil 1 ??
Old Oct 24, 2002 | 09:03 PM
Dan GSR's Avatar
I did mine tonight with the mobil 1 ...
I had to take off the bracket that holds the intake manifold to get the filter to fit.....no biggie....its just an extra pound of metal that isn't really doing anything..
New User
MOBIL 1 105 It's almost twice the size
Old Oct 24, 2002 | 09:05 PM
New User
Yeah I pulled that bracket too.
Old Oct 24, 2002 | 09:21 PM
25 Year Member
tell me if you see any results
Old Oct 24, 2002 | 09:32 PM
M0NEYnH0s's Avatar
any concern for oil leaks with the higher pressure on a high mileage engine?
Old Oct 24, 2002 | 09:37 PM
Dan GSR's Avatar
Default Re: Any negative effects of using oversized filter?? (m0neynh0s)
not 100% sure on this....
but I don't think it creates more pressure...you just loose less pressure with the oversized filter.....therefore less oil starvation??
Old Oct 24, 2002 | 11:16 PM
Brad's Avatar
I tend to agree with you on that, because didn't people use smaller rsx oil filters to raise the oil pressure, so bigger would make less pressure. Sounds reasonable...
Brad
Old Oct 25, 2002 | 09:49 AM
Dan GSR's Avatar
Default Re: Any negative effects of using oversized filter?? (Brad)
that doesn't make sense....with a smaller filter wouldn't it be more restrictive...so you would lose some oil pressure....with the oversized filter you don't make more oil pressure....just that its less restrictive so you don't lose as much pressure ( so i guess in a way it does increase oil pressure)
am I right??
Old Nov 1, 2002 | 08:17 PM
Dan GSR's Avatar
Update
some reason I'm getting better gas mileage
Old Nov 1, 2002 | 09:55 PM
ingrate's Avatar
25 Year Member
You're not necessarily looking for more oil pressure when you shop for an oil filter. mainly it's how well the filter element cleans out the oil and how well the oil flows through it. obviously, a bigger filter will have less restriction because there's more surface area for the oil to go through.. i don't really see any advantage to upping the oil pressure, unless someone could explain this to me..?
petec59
Honda Civic (2006 - 2015)
16
Apr 19, 2007 12:21 PM
Elfstone
Sep 20, 2004 04:12 AM
del_parker
Sep 16, 2003 06:32 PM
dclub01
May 1, 2003 03:22 PM
Catch 22
Jan 27, 2002 04:22 PM
