Alternator or battery problem?
Old Feb 4, 2006 | 08:38 AM
candy eg's Avatar
From: The Real O.C. Oakland Chinatown, California, USA
Default Alternator or battery problem?
i've been having problems with my car lately. when i start up my car it takes a while to, and when i will be driving the cluster light dims and my radio goes on and off and my lights flicker bright and dark. so i replaced the battery. for a couple starts it started up fine and ran good. then one time before a drive, i tried to start my car it would go to the second slot but when i try to start it up it, i just heard clicking noise. i tightened the start plugs, and after a few more tries, it worked. then on that drive home, samething happens, my lights start to dim and my radio kept going on and off and the cluster was just dead. is it a battery or alternator problem?
Old Feb 4, 2006 | 08:56 AM
jmcool's Avatar
Default Re: Alternator or battery problem? (candy eg)
sounds like the altenater. same thing happened to me a while back
Old Feb 4, 2006 | 09:10 AM
candy eg's Avatar
do u think its a dumb idea to drive on it for a couple more drives? because i gotta get to places and stuff..
Old Feb 4, 2006 | 09:14 AM
TRE_'s Avatar
you can drive it still, but theres a possiblity that the alternator will go out completley when youre going somewhere,,, leaving you stuck on the side of the road. i would just get it fixed ASAP and try not to drive very far.
Old Feb 4, 2006 | 10:31 AM
LSvtec03's Avatar
Default Re: Alternator or battery problem? (TRE_)
electrical problem while running - alternator
electrical problem starting - battery (starter, etc)
the battery doesnt power anything while the car is running. it all comes from the alternator.
Old Feb 4, 2006 | 01:59 PM
t_c_l_6's Avatar
Default Re: Alternator or battery problem? (LSvtec03)
you can still drive it, just make sure the battery has enough charge so it doesnt die on you while your driving, and like TRE said dont try to drive too far
Old Feb 4, 2006 | 02:36 PM
TRE_'s Avatar
Default Re: Alternator or battery problem? (t_c_l_6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t_c_l_6 &raquo;</TD></TR><TR><TD CLASS="quote">you can still drive it, just make sure the battery has enough charge so it doesnt die on you while your driving </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSvtec03 &raquo;</TD></TR><TR><TD CLASS="quote">electrical problem while running - alternator
the battery doesnt power anything while the car is running. it all comes from the alternator.</TD></TR></TABLE>
HELLAnorcal
Jun 12, 2007 04:25 AM
jdmkrazie
Jun 1, 2004 09:16 PM
shadowdawn
Aug 9, 2003 06:23 PM
EJK
Feb 4, 2003 08:03 PM
714eg
Jan 16, 2002 03:21 PM
