Are all speedometer gauges the same?
Old Jan 11, 2008 | 10:16 AM
fastcrvi's Avatar
Default Are all speedometer gauges the same?
Is there a difference between ls, gsr and itr cluters as far as speedometer goes? does it calculate speed differently or they're all the same aside cosmetic appearance
Old Jan 11, 2008 | 10:59 AM
BlueIntegraBoy's Avatar
Default Re: Are all speedometer gauges the same? (fastcrvi)
All the same. Just cosmetically different.
Old Jan 11, 2008 | 01:06 PM
dwolsten's Avatar
Default Re: Are all speedometer gauges the same? (BlueIntegraBoy)
Yep, they use the same speed sensors and connectors; they should be interchangeable.
Old Jan 11, 2008 | 02:19 PM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: Are all speedometer gauges the same? (dwolsten)
+3 for same
Old Jan 11, 2008 | 07:52 PM
fastcrvi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwolsten &raquo;</TD></TR><TR><TD CLASS="quote">Yep, they use the same speed sensors and connectors; they should be interchangeable. </TD></TR></TABLE>
are you 100% sure? i know they're interchangable from car to car.. but if they have same speed sensors, how do they compensate for differencei ngearing? itr gearing would be going 80 mph at 4.5krpm while ls would only be doing 60mph at 4.5k rpm... something has to be diffeernt.. so what is the difference?
Old Jan 11, 2008 | 09:17 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastcrvi &raquo;</TD></TR><TR><TD CLASS="quote">
are you 100% sure? i know they're interchangable from car to car.. but if they have same speed sensors, how do they compensate for differencei ngearing? itr gearing would be going 80 mph at 4.5krpm while ls would only be doing 60mph at 4.5k rpm... something has to be diffeernt.. so what is the difference?</TD></TR></TABLE>
Speed sensors are the same.
Old Jan 11, 2008 | 10:06 PM
Mfoehrkolb's Avatar
--- If you look @ LS cluster and GSR cluster. the MPH are the same, but the RPM's are @ different positions, making for the slight difference. I was wondering the same thing about speeds with rpms after i switched out my clusters, and my friend brought it to my attention that the positioning of the numbers were slightly different.
BOS#20
Jun 12, 2006 08:04 AM
ITR0952
Oct 12, 2004 12:17 PM
JDMITR22
Acura TL, RL & ZDX
14
Mar 2, 2004 08:19 AM
Flux
Dec 1, 2003 06:04 PM
Donkey85
Nov 7, 2003 12:00 PM
