alignment
Old Dec 9, 2003 | 11:19 AM
R.S.'s Avatar
Default alignment
i installed Koni yellow shocks, ITR rear LCA's, ITR rear 22mm sway bar, and sum otha **** like a month ago......
I ran out of money and it's winter, so i said **** it and i'm waitin till spring to get my Custom spring rate ground controll coilovers. So i had the ITR rear springs, i put those on and set the koni perch to it's highest setting. For the front i just used the stock springs and put the neuspeed koni's on there lowest purch....
do i need to get an alignment now, or should i wait till i install the GC coilover sleeves?
Old Dec 9, 2003 | 04:22 PM
R.S.'s Avatar
Default Re: alignment (R-Spec)
bump
Old Dec 9, 2003 | 04:28 PM
Johnny Gasparini's Avatar
I didn't ask for a dime.
Anytime you jack with the suspension, it is best to do an alignment
Old Dec 9, 2003 | 04:29 PM
FlaN.'s Avatar
well you should get an alignment right after you put your suspension on, but me..... it's been three weeks since i've put my teins on and i still havent gotten it. no one will do it because it's too low, so im still in search. so yes, if u can get an alignment.
Old Dec 9, 2003 | 05:42 PM
integraL's Avatar
Default Re: (theJUMPoff)
i heard you're supposed to wait like 200 miles before you get an alignment
Old Dec 10, 2003 | 04:30 AM
JimBlake's Avatar
Default Re: (integraL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraL &raquo;</TD></TR><TR><TD CLASS="quote">i heard you're supposed to wait like 200 miles before you get an alignment</TD></TR></TABLE>Yeah, I've heard that too. Gives the components some time to rattle around & settle into place.
Old Dec 10, 2003 | 07:30 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: alignment (Jason M)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jason M &raquo;</TD></TR><TR><TD CLASS="quote">Anytime you jack with the suspension, it is best to do an alignment</TD></TR></TABLE>
More specifically, anytime you change the ride height, you should get an alignment.
You can take off springs, shocks, LCA's, whatever as much as you want and the alignment will remain the same, as long as the ride height doesn't change.
Old Dec 10, 2003 | 11:17 AM
R.S.'s Avatar
Default Re: alignment (PatrickGSR94)
my ride hight only changed like 15mm
but i think it's best to wait till the springs settle befo getting an alignment, so i waited.....
Old Dec 10, 2003 | 12:29 PM
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R-Spec &raquo;</TD></TR><TR><TD CLASS="quote">my ride hight only changed like 15mm
but i think it's best to wait till the springs settle befo getting an alignment, so i waited.....</TD></TR></TABLE>
that will still affect toe-in, so you still need an alignment. I got mine done about 2 weeks after installing my stuff. And I usually get it checked every 6 months or so just to make sure it's in check, since I'm lowered so much w/o camber kit, so toe-in settings are critical.
cheapskate
Nov 7, 2015 01:44 PM
HRubss
Apr 25, 2015 04:01 AM
Murk 'EM
Mar 7, 2011 10:16 AM
project dc2
Nov 15, 2002 05:09 AM
B00STeD
Jun 22, 2002 07:05 AM
