Alignment???
Ok, about a week ago i got my new 15" rota C8's put on, and when i did that i got a alignment since i thought i wasnt gonna lower my car n e time soon. But i found a good deal through my friend on some sportline springs and shocks together for $125 so i got it. I put them on and now im about a 2 finger gap in back and about a 2.5 finger gap in front. Should i go back and get another alignment??? Just trying 2 save $69.00 if i dont need 2 spend it.... TIA
yea you should go get an alignment.. anytime you adjust the height it throws off the suspensions settings. BTW, are those aftermarket or stock shocks you got for 125?
most important are the tow-in settings. Out-of-spec toe along w/ negative camber will kill a tire. You can run some negative camber, though, as long as the toe settings are correct and you rotate tires often. This is what I'm doing and I've had no problems yet.
yep, any change in ride height affect both camber and toe-in settings. I advise you to either try to find a place w/ a lifetime alignment deal, or set the car where you want it, get it corner weighted and dialed in, get it aligned the way you want it, and then don't mess with the settings.
Kronn 98SH
Suspension & Brakes
Jun 21, 2005 06:08 AM
