afc settings
ok installed my safc everything is hooked up right, but i don't know how to program it
i put in the settings i thot were correct but apparently they're not lol..
for sensor type i put it was a Pressure.. for the in i put 06 and for out it was left at 01
for the type of car i selected 4 cylander and as for the thr i left that w/ the diagonal up arrow.. i didn't know how to set that one.
other than that i left the safc the way it came programmed.. can someone help me out here.. this car is my daly driver
i shoulda researched this more than just jumping into installing it w/out knowing how to set it so my car will run..
thanks in advance-
christian
[Modified by xjdm94x, 5:07 AM 12/3/2002]
i put in the settings i thot were correct but apparently they're not lol.. for sensor type i put it was a Pressure.. for the in i put 06 and for out it was left at 01
i shoulda researched this more than just jumping into installing it w/out knowing how to set it so my car will run.. thanks in advance-
christian
i turn it on and then it shuts right off.. sometimes it will turn on and idle for a second or 2 then die.. and one time it started and idled for a little bit but once i hit the gas it shut off.
hmm.. well i left it at 6 and 1 then i tried 6 and 0 haha that didn't work.. then i turned it up to 6 and 6 but then the car turned off right away.. i duno.. i should mess w/ it some more i guess..
Make sure that you have all your wiries hooked up right! I think the 6in 6 out is ref. to how many readings you want it to take and yes throttle pos. should be up.
yeah.. i was reading the directions to my friends vafc and it says to have it as 6 in 6 out.. but maybe it's different for me sinc ei'm non vtec?
Thinking back, it should be 6 in and 6 out I THINK. I'll double check mine for you later if you'd like.
Seriously, triple check your connections. Check your grounds, specifically. The safc is very picky. Make sure the two grounds are about a cm apart.
Adam
Adam
i had one of those in my car.... safc.....well double check ur wiring then 6 in and out, arrow up , 4cyl.....but the way it sounds u probably connection on the map sensor is wrong....this the one u bypass the map sensor wire on the ecu...check it again
thanks for the help guys.. i don't know if this will be running right yet because my TPS is broken
so once i replace that hopefully everything will be running right..
