why can't i have a/c in an integra with a 3" downpipe?
Old 02-25-2004, 05:23 PM
CrazyModGSR's Avatar
Default why can't i have a/c in an integra with a 3" downpipe?
Might be buying this turbo teg, but noticed it has a 3" downpipe. I've read before that you can't have air conditioning if anything larger than a 2.5" downpipe is used? Why exactly is this; what part gets in the way of the downpipe? I definitely will need my a/c in the summer.
Thanks in advance
Tim
PS - I used the search button with no help.
Old 02-26-2004, 06:39 AM
Rod.'s Avatar
Default Re: why can't i have a/c in an integra with a 3" downpipe? (CrazyModGSR)
they make kits, check full race
Old 02-26-2004, 06:51 AM
quikB18B's Avatar
Default Re: why can't i have a/c in an integra with a 3" downpipe? (redturbocivic)
The typical 3" downpipe won't clear the A/c compressor.
full race has made a 3" compatible kit, where the downpipe work's with A/c so it's not impossible, but most 3" donwpipes are not a/c compatable.
A friend of mine rigged his 3" Dp to work with A/c, basically he cut the Dp, and made the angle alot shorter and sharper to clear the A/c. Im not 100% sure if he benifits more from a 3" DP, with a sharper bend, or a 2.5 Dp with a more flow friendly bend.
Why don't you just ask the seller if the car has a/c?
Old 02-26-2004, 07:16 AM
B A N N E D
vtecb20coupe's Avatar
Default Re: why can't i have a/c in an integra with a 3" downpipe? (quikB18B)
thought most people with turbo's didn't have a/c?
Old 02-26-2004, 08:33 AM
tegmech's Avatar
Default Re: why can't i have a/c in an integra with a 3" downpipe? (vtecb20coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecb20coupe &raquo;</TD></TR><TR><TD CLASS="quote">thought most people with turbo's didn't have a/c?</TD></TR></TABLE>
depends on how extreme you want to go.
You can have a high performing car w/ac if you look hard enough. Full Race, and Lovefab make some of the best (imo) ac compatible turbo manifolds that allow for 3"-4" downpipes.
Old 02-26-2004, 08:35 AM
Audi A4's Avatar
SHIITTTTT
Old 02-26-2004, 08:43 AM
FlaN.'s Avatar
**** that! haha, a lot of peeps get rid of it b/c the availability of parts goes up when you don't have A/C, plus the install is easier..
Old 02-26-2004, 11:29 AM
bo0sted's Avatar
Default Re: why can't i have a/c in an integra with a 3" downpipe? (theJUMPoff)
You can run a 3" dp with AC. Mostly depends on your manifold, but who needs AC anyways.
Old 02-26-2004, 12:07 PM
quikB18B's Avatar
Default Re: why can't i have a/c in an integra with a 3" downpipe? (MwGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MwGSR &raquo;</TD></TR><TR><TD CLASS="quote">You can run a 3" dp with AC. Mostly depends on your manifold, but who needs AC anyways. </TD></TR></TABLE>
Well i guess you don't need it in Illinois, but here in Texas unless you like Sweat stains on your back all summer long then A/c is a must
Old 02-26-2004, 12:46 PM
jdmintegls's Avatar
you need A/C here in vegas dude....100-115 during summertime
Old 02-26-2004, 12:54 PM
bo0sted's Avatar
Default Re: (jdmintegls)
Chicago summers arent the hottest tempature wise but the humidty here in the summer will own you.
Old 02-26-2004, 01:07 PM
Xx94GSRxX's Avatar
yea here in texas- drip. near ausint i'd die w/ out a/c heh
Old 02-26-2004, 01:11 PM
NuclearB18B's Avatar
you'd have to be insane not to keep a/c in texas...
Old 02-26-2004, 07:57 PM
Default Re: why can't i have a/c in an integra with a 3" downpipe? (ha illuminato un)
i just called the guy last night. he said the 3" d/p was custom made. he says it stills has a/c and never had to remove any a/c components. i want performance, but definitely will want my a/c on those hot 80-100 degree days come summer.
thanks for the help
Old 02-26-2004, 08:15 PM
mad24dog24's Avatar
Texas and Vegas are sure hot but its more of a dry hot...in Florida it gets up there but then theres that humidity that is just aweful, IMO worse then those dry states (btw I too am looking for a 3 inch downpipe w/ AC)
Old 02-27-2004, 06:25 AM
bo0sted's Avatar
Default Re: (mad24dog24)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mad24dog24 &raquo;</TD></TR><TR><TD CLASS="quote">Texas and Vegas are sure hot but its more of a dry hot...in Florida it gets up there but then theres that humidity that is just aweful, IMO worse then those dry states (btw I too am looking for a 3 inch downpipe w/ AC)</TD></TR></TABLE>
Exactly the humidity is what kills you. I've been in the AZ desert at almost 120 degrees and i **** you not it felt better then a day at Chicago with 100 degree tempature and 100% humidity.
Old 02-27-2004, 07:48 AM
IntegraLs94Cam's Avatar
Default Re: (MwGSR)
lol i know what u mean
Old 02-27-2004, 12:45 PM
i wouldn't call it a dry hot in dallas...a hundred degrees and eighty percent humidy is pretty uncomfortable...just my two cents though
Old 02-27-2004, 03:11 PM
slowww b18b1's Avatar
Default Re: (ha illuminato un)
ya u northerns dont get that it can get hot as hell and a/c is a must unless u wanna drown in ur own sweat, lol. when i get my turbo ill be keepin my a/c too
Old 02-27-2004, 04:41 PM
92HB_HB's Avatar
Default Re: (B18B1-turbo)
being hot in dry weather is one thing... being hot in muggy weather is a whole differnent story especially at night..
Old 02-27-2004, 05:29 PM
Spoon Spec EK's Avatar
Default Re: (92HB_HB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92HB_HB &raquo;</TD></TR><TR><TD CLASS="quote">being hot in dry weather is one thing... being hot in muggy weather is a whole differnent story especially at night.. </TD></TR></TABLE>
word.
Old 02-27-2004, 06:11 PM
New User
SIK IN DA HED's Avatar
why are you so concerned with having a 3in downpipe anyway? if youre power goals require you to have an exhaust of that size... then cool. if not, you can always get a 2.5 for the summer and slap the AC on. =P
Old 02-27-2004, 09:34 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18B1-turbo &raquo;</TD></TR><TR><TD CLASS="quote">ya u northerns dont get that it can get hot as hell and a/c is a must unless u wanna drown in ur own sweat, lol. when i get my turbo ill be keepin my a/c too </TD></TR></TABLE>
??? I don't know how many of you have been to Connecticut or New England in the summer, but it gets just as hot as any other state and VERY muggy. June-August can easily be 80-100+ with equally high humidity. I have talked to the guy, and he said it's a custom made 3" downpipe and he didn't have to remove any a/c components when installing it.
Thanks for the help though
Old 02-27-2004, 11:57 PM
Miz101's Avatar
Default Re: (MwGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MwGSR &raquo;</TD></TR><TR><TD CLASS="quote">Exactly the humidity is what kills you. I've been in the AZ desert at almost 120 degrees and i **** you not it felt better then a day at Chicago with 100 degree tempature and 100% humidity. </TD></TR></TABLE>
I hate summer because of the humidty.
Oh well at least I don't have to wear 45 jackets just to check my mail during winter.
Old 02-28-2004, 06:11 AM
Rory Breaker's Avatar
Basically because of the positioning of the downpipe, its difficult to maintain a full 3" diameter while having a sharp enough bend off the flange to go down underneath the car.
A common way people have gotten around this is a 2.5" to 3" flare.
Quick Reply: why can't i have a/c in an integra with a 3" downpipe?
