AC Help
Old Aug 31, 2006 | 12:32 PM
Bonestock98GS's Avatar
Default AC Help
Hey guys how are you doing I have an important question about my AC. Well I was riding the other night and my AC was working fine and when I went to shut it off the pther night it made this funny squealing noise so I turned it on and off again to see if it would make that noise but the noise continued. Today I went to turn the air on and hot air came out. Would it be an AC recharge in need or a burnt compressor? I was plannin on going boost anyways and I was wondering if it would better to be with out AC anyways
Old Aug 31, 2006 | 04:01 PM
Default Re: AC Help (Bonestock98GS)
Bump! Does anyone know much about this question becuz I am stuck
Old Aug 31, 2006 | 06:36 PM
Lewie's Avatar
I'm here for the gangbang!
I have a feeling the compressor is locked up.
If this is a DC, then you're going to have to replace the compressor, drier, exp valve, and put in an in-line filter. If you wait too long (a few months) ther is a residue that builds up in the system and creates an acid which eats away at the evaporator.
do you have an aftermarket intake? if you do, you're goign to have to check the AC hose that runs under it. A lot of intakes will rub that hose and create a hole which causes the refrigerant to leak out.
Old Sep 1, 2006 | 04:54 AM
Yea I Do have an aftermarket intake and I am going to check to see if it rubbbed against that hose today thanks bor any more comments would be great
Old Sep 1, 2006 | 05:35 AM
Lewie's Avatar
The replacement parts are not that expensive. I got everything I needed, including an evaporator for $200. The install is the most expensive part.
Old Sep 1, 2006 | 05:39 AM
I was going to boost my DC2 anyways do you really think I should worry about the ac that much I am looking to hit the 400 hp mark I may just remove power steering also
Old Sep 1, 2006 | 05:47 AM
Lewie's Avatar
Default Re: (Bonestock98GS)
If you're looking to get 400hp w/ a turbo setup, then you may want to think about removing the AC and PS to allow for bigger piping, turbo, manifold, etc.
It's all up to you though. I went without AC for 2 years, and it wasn't bad until I wanted to take a girl out. The summer's in FL are hot as hell.
Old Sep 1, 2006 | 05:50 AM
I know man I felt the wrath of that beautiful states heat before lol. Yea I am going to remove all of that un-needed stuff did you boost ur non ac car?
Old Sep 1, 2006 | 05:57 AM
Lewie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bonestock98GS &raquo;</TD></TR><TR><TD CLASS="quote">I know man I felt the wrath of that beautiful states heat before lol. Yea I am going to remove all of that un-needed stuff did you boost ur non ac car?</TD></TR></TABLE>
at first that was my plan, but I never got around to turboing it and I was too cheap to get it fixed.
threeoten
Honda Civic (2001 - 2005)
Aug 10, 2016 08:31 PM
disboitrung
Aug 5, 2008 07:28 PM
vietnogi
May 24, 2005 08:01 AM
J-Brooks
22
Jun 21, 2003 03:10 PM
