ABS question....
Old Apr 8, 2004 | 08:49 PM
wanna b R's Avatar
Default ABS question....
today i was driving my car...then i saw my abs light turn on for like 10 sec then off
....then later turns on again....5 sec later its off again......if my abs messed up?
Thanx for any info
1994 LS
Old Apr 8, 2004 | 08:58 PM
Boges's Avatar
Default Re: ABS question.... (wanna b R)
I would check the wheel speed sensor on the knuckle.
Old Apr 8, 2004 | 09:08 PM
wanna b R's Avatar
Default Re: ABS question.... (Boges)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boges &raquo;</TD></TR><TR><TD CLASS="quote">I would check the wheel speed sensor on the knuckle. </TD></TR></TABLE>
.....where is that located?...(sorry stupied question)
Old Apr 8, 2004 | 09:19 PM
Boges's Avatar
There are two small bolts that hold it to the back of the knuckle right above the lower ball joint. It also has a wire connected to it that runs up the knuckle, so you should be able to tell right away it's a sensor.
This may not be the solution but it's the first thing I can think of.
Old Apr 8, 2004 | 09:20 PM
Sprayin DC4's Avatar
yeah
Old Apr 8, 2004 | 09:29 PM
revautousa's Avatar
probably want to check your fluid also, that happens to me alot.
Old Apr 8, 2004 | 09:32 PM
timmy8151's Avatar
Default Re: ABS question.... (DA JeLLie)
The very first thing you should do is pull the ABS code. You need to jump the service connector and read the flashes.
Old Apr 9, 2004 | 05:11 PM
wanna b R's Avatar
Default Re: ABS question.... (timmy8151)
thanx for the info guys
94BlkCivicEx
12
Oct 22, 2009 08:49 AM
manuelesr
Apr 13, 2008 01:08 PM
Kiko
Honda S2000
10
Aug 6, 2007 06:33 AM
LukieLuc
Mar 22, 2007 11:05 AM
TerribleOne
Mar 19, 2003 10:59 AM
