ABS light question
i have a 94 gsr...and some times when i go over bumps or take a turn crazy fast, my abs light comes on. You think it could be my rear tie bar is pinching something in the back? any other people have the same problem?
If you think it is the rear bar check it before it cut your ABS lines. That would suck.
Is your ABS motor pump comming on alot? During driving.
You know that 2 second bussing noise when you start your car.
~Andy~
~Andy~
i never knew that was the sound of the abs pump...i've heard it really loud in the 99+ preludes, but i do hear it those frist 2 seconds. I'll try to listen again to see if it comes on when i'm driving. thanks for the advice, i appreciate it !
Jay
Jay
what does it mean if ur ABS pump is coming when ur driving?
mine comes on when i start the car and stays on for a while, when it goes off the ABS light comes on. Sometimes when i start it, the pump doesnt make the sound and the light doesnt come on, then ill be driving and ill hear it buzzing and when it stops the ABS light comes on. Brakes work fine and when i stompem hard I feel the ABS working so idk, im just to broke to get it fixed right now.
ramz7887
Mar 22, 2007 07:51 PM
