abs light came on!
If you have a '94-'97 Integra check the ABS fluid reservior (connected to the ABS module) for proper fluid amount and also check to see if the ABS module is leaking fluid.
that buzzing is normal.
Is it only once you start moving?
make sure the hubs are clean.. dirt will throw off the sensors (they are electro magnets) and rocks/etc.. will confuse them.
