ABS light
well the other day i installed my sway bar and tie bar on my 96 integra ls. Then when i started the car i realized my ABS light was on? any ideas what might be the problem??
Pull the code & see... Just like reading ECM codes, you jumper the SCS connector & count the flashes. The ABS light will be blinking instead of (or in addition to) the check-engine light.
Maybe you disconnected a wheel sensor when you were working??
I did the same thing. Installed the ITR sway and the abs came on. Pulled the code and it was the right wheel sensor. Still havent' really bothered with it yet...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake »</TD></TR><TR><TD CLASS="quote">Pull the code & see... Just like reading ECM codes, you jumper the SCS connector & count the flashes. The ABS light will be blinking instead of (or in addition to) the check-engine light.</TD></TR></TABLE>
explain how that works... as funny as it sounds, pulling the codes that way is new to me. i was used to reading codes in my acura legend by just looking at the blinking LED and counting the flashes. so simple.
so what do you mean by jumping the SCS connector?
