abs light
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aaronISthrowed »</TD></TR><TR><TD CLASS="quote">Check to see what code its throwing and see what the problem is. Look in the FAQs the 1st link will tell you what to do.</TD></TR></TABLE>
Exactly. In most cases that I've seen it's usually just a faulty sensor.
most likely a sensor, you see many lights on hondas reason being is that its a fairly primative abs system and being older cars they just **** the bed over time i replaced my sensors and then gave up over time and yanked the light out so i dont have to look at it.... but just because the abs light is on and the abs isnt working has nothing to do with normal brakes it just means you dont have abs which is a completely separate system
