ABS light
Old Feb 16, 2006 | 10:50 AM
Bngo731's Avatar
Default ABS light
my abs light is on but it only comes on every now and then. sometimes it will just turn on and sometimes it will be off. whats my problem. i have a 97 gsr.
Old Feb 16, 2006 | 11:00 AM
cm zak's Avatar
Had the same problem for a while, only about a week or two, 98 LS, but after a while it stopped....Dont know, have you tried resetting the ECU?
Old Feb 16, 2006 | 11:15 AM
LoseRPunKx182's Avatar
Default Re: ABS light (Bngo731)
check the end of the first post
https://honda-tech.com/zerothread?id=978933
Old Feb 16, 2006 | 01:04 PM
92gisser's Avatar
probably a wheel speed sensor, seems to be the most common component on the abs that goes bad. easy fix, though.
Old Feb 16, 2006 | 04:42 PM
teddy_dc2's Avatar
is the car lowered? my light only comes and stays on after i drive off. my sway bars bushings poped out of place and abs doesn't work. i think cause the car is too low.
Old Feb 16, 2006 | 05:40 PM
.xcalibur.'s Avatar
Check for any ABS codes. Then reset the ABS system. It doesnt work the same way as resetting the ECU.
DTC Erasure procedure taken from the Integra Service manual.
1. Short the service connector.
2. Press on the brake pedal.
3. Turn the ifnition switch ON position while holding the brake down.
4. When the ABS light goes off, release the brake pedal.
5. When the ABS light come on, press the pedal.
6. When the ABS light goes off, release the brake pedal again.
7. After a few seconds, the ABS light will blink twice and the ABS code is erased. If it does not blink twice, repeat steps 1-6l. If the Indicator stays on after the indicator blinks twice, check the code again because there was a problem detected during the initial diagnosis before shifting to the Erasure mode.
Old Feb 16, 2006 | 06:12 PM
teddy_dc2's Avatar
what do you suggest is wrong in my case? will it work if i reprogram it even though car is still lowered? abs work fine when i first lowered it until my dumb cuz took it touring.
Old Feb 17, 2006 | 06:58 AM
.xcalibur.'s Avatar
you wont know whats wrong with it until you check the codes.
Old Feb 17, 2006 | 07:22 AM
CleanLikeJdm's Avatar
Hype-R Stalker
It could be the bulb, try taking it out and see if it still comes on
No but seriously, I kinked my abs line a little on the one side when doing some suspension work, and I have the light on all the time now.
So it could even be some little thing, I have no problems with my abs,
and I've stepped on the brakes hard a couple time afterwards.
Old Feb 24, 2006 | 11:50 AM
Bngo731's Avatar
well i did lower my car recently so that may be the problem?
Kozy.
Engine Management and Tuning
Apr 30, 2013 10:22 AM
DC231_01
Jun 26, 2006 08:37 PM
94~GSR
Sep 30, 2005 10:33 PM
JDAN
Nov 17, 2004 06:08 AM
redteg1
Aug 18, 2001 02:42 PM
