abs failure
Old Nov 10, 2005 | 07:54 PM
soontobeboost's Avatar
Default abs failure
hey so my abs light came on aobut a month ago and i pulled the code today and its 6-1
so i searched it up and it said its fail safe relay (f)
do you guys know where this relay is located?
Old Nov 11, 2005 | 07:33 PM
97tegGS's Avatar
00 GSR
97LS
Both are located toward the right front.
Wasnt sure which braking system you had so there is both
Old Nov 17, 2005 | 10:05 AM
Default Re: (97tegGS)
thats not it... i called acura and gave them the number on the relay and the guy said it was for a/c../ i have a 96 gsr if that makes it any different. i need to find this quick so i can fix it before the rain comes...
help HELP!!!!
Old Dec 12, 2005 | 02:46 AM
jdm tommy's Avatar
Default Re: abs failure (soontobeboost)
have the same code would also like to know BUMPPPPPP
Old Dec 12, 2005 | 03:25 AM
suzawa94's Avatar
Default Re: abs failure (jdm tommy)
code 6-1 is indeed the fail-safe relay circuit. on our 96 it's located by the RF headlight, right below it.
to check relay, check for continuity between terminals C and D. do the same for A and B and C and D.
*note*-terminals C and D should have continuity when battery is connected and no continuity when off.
the procedure above is only for checking the relay itself. if not the relay, visually inspect the wiring if there are any frays or loose connections. if all else fails, let me know-i have the OEM repair manual for the 96 Integra.
Old Dec 12, 2005 | 04:07 AM
jdm tommy's Avatar
aww crap mines a 6-1 for a 98+ ignition voltage anyone know the difference????
secur60
Jun 14, 2024 08:57 PM
IamPhil
Jan 30, 2008 03:27 AM
IamPhil
Jan 4, 2008 07:42 AM
BoltonGSR
Dec 1, 2007 08:06 PM
NorthernXposure
Sep 20, 2007 12:02 PM
