about to strip the inside....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carless87 »</TD></TR><TR><TD CLASS="quote">ok im thinkin about striping my 95 teg rs....would u say is worth doin in like saving weight....????</TD></TR></TABLE>
i guess u cant read...
i am thinking about striping my 95 integra inside....backseats...ect....
i want to know if it saves anyweight to make a diff...
i want it to be lighter for autocross to get better times and the facted i dont use them ever.
so do u think i should
or
or
it depends...do you care what class you autox in??
can you deal w/ the xtra road/ exhaust noise??
can you deal w/ ppl thinking your car is a piece of **** because it has no interior??
all for 40lbs max???
its up to you..if you dont like you can always put it back in...
Weight Reduction=CRAP
, WR should only be used for drag. PPL these days...Ehh, what are you going to do when you have to take your girlfriend with you? LoLz
You want to lose weight for motorX? First off you should just leave all the interior and go all motor work! Bad decision if your going with weight reduction, side panels, back seats, spare tire, etc, MAX=40lbs
If youre going to do some weight reduction, why not do it elsewhere, like in the drivetrain. Unsprung weight is worse than sprung weight, so focusing on moving components will help more at autox than stripping the interior. Maybe you could lighten up the front (lighter hood, axles, suspension + engine parts), since the front/rear weight balance is off due to the fwd, but I wouldnt suggest stripping the interior. Good luck man!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by morocco »</TD></TR><TR><TD CLASS="quote">If youre going to do some weight reduction, why not do it elsewhere, like in the drivetrain. Unsprung weight is worse than sprung weight, so focusing on moving components will help more at autox than stripping the interior. Maybe you could lighten up the front (lighter hood, axles, suspension + engine parts), since the front/rear weight balance is off due to the fwd, but I wouldnt suggest stripping the interior. Good luck man!</TD></TR></TABLE>
he speaks the truth.
I drove with a completely stripped interior for a week or two last winter while trying to diagnose my water leaks, and I hated every minute of it. It was SO loud inside, looked horrible. When I say stripped I mean no carpet, no console or shifter boot, no rear side panels, no passenger seat, nothing. Inside the car was the driver seat, steering column and dashboard and door panels and that was it.
If you autocross it will bump you out of your class most likely unless you already run in a modified class.
Don't do it unless it's strictly a race car only.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 »</TD></TR><TR><TD CLASS="quote">I drove with a completely stripped interior for a week or two last winter while trying to diagnose my water leaks, and I hated every minute of it. It was SO loud inside, looked horrible. When I say stripped I mean no carpet, no console or shifter boot, no rear side panels, no passenger seat, nothing. Inside the car was the driver seat, steering column and dashboard and door panels and that was it.
Don't do it unless it's strictly a race car only.</TD></TR></TABLE>
Did you find the source of the water leak?
Where was it?
Where was it?
....ok i took it out and i kinda like it bec my car already makes alot of noise with everything in so nuthing changed really.and like Jerms said i hate giving people rides.
From: Good luck to this industry, you're gonna need it.
you're gonna stripe the inside? really? wow...
of course it's worth it if you take EVERYTHING out...every little bit helps but you can always put it back. The factory sound deadening crap on the floor is pretty heavy stuff if you can get that out, it would be a nice help to your goal.
look im fat and short and still dont have a problem with the ladys so im all good hahahahha.....even tho all the girls i know r myspace hoes....lol
It's going to suck for daily driving. Mine is gutted, and it sucks lol. You can't even sleep in your own car. I found this out last night, when I let my friend drive so I can try to sleep, but didn't.
Dude send some myspace ****** my way! haha
