Which is which??
Old Oct 29, 2006 | 01:11 PM
LoNgHoRn's Avatar
Default Which is which??
Hi I'm in UAE....i found one ACURA Integra which came from Canada...Now my question is which one is the later model...the one with the quad lites or the longer headlights?? It has a B18c1 engine....pls help...the one I found is the one with the longer headlites...
Another question..when I started the car...the SRS light doesn't turn off...and a light which says maintenance needed in the panel gauge...is it the same as the Check engine light or a minor thing?? How can I turn-off the SRS light and what may seem to be the problem?? Please help before I buy this car...Thank you..
Old Oct 29, 2006 | 01:30 PM
SoTexDC2's Avatar
Default Re: Which is which?? (LoNgHoRn)
SRS light means airbags aren't working. Maintnence required light is an idiot light. Theres a switch below the dash, somewhere under the steering wheel. Just hold it until it flashes, and the light will shut off. Not sure on the headlights, pics?
wardseg6
Honda Civic (2001 - 2005)
Jul 21, 2007 11:40 PM
Caveman74
Oct 30, 2006 02:55 PM
StolenTeg
Nov 28, 2004 08:19 AM
