98 integra gsr cel code p0108 problem help
Old Apr 12, 2008 | 11:37 PM
joetdk's Avatar
Default 98 integra gsr cel code p0108 problem help
deleteeee
Old Apr 13, 2008 | 06:09 AM
blkb18's Avatar
Default Re: 98 integra gsr cel code p0108 problem help (joetdk)
double check your ignition timing, if thats ok I would double check your engine timing.
Old Apr 13, 2008 | 08:15 PM
joetdk's Avatar
Default Re: 98 integra gsr cel code p0108 problem help (blkb18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkb18 &raquo;</TD></TR><TR><TD CLASS="quote">double check your ignition timing, if thats ok I would double check your engine timing.</TD></TR></TABLE>
both are dead on
Old Apr 14, 2008 | 02:13 PM
joetdk's Avatar
still need an answer for this cel problem
Old May 15, 2008 | 09:18 PM
joetdk's Avatar
ok well more info the car was turbo before ig to it would that have any thing to do with this cel
also i went to the shop and my timing was off that is why the car was running like crpa and not taking off fast but now it does that the timing is strait on
but i still got the cel light pleasehelp i need it gone
Old May 16, 2008 | 05:46 PM
blkb18's Avatar
How much boost and what map sensor are you running?
Old May 17, 2008 | 02:52 AM
faejai's Avatar
hope u find out the problem i had the same code + missfire on all 4 cylinders, changed spark plugs,wires, cap n rotor, map sensor, tps, still throwing same codes. until i had ref ticket n had to switch out my itr head + sk2 im and sk cams to stock gsr head, everything went away... hope it doesnt come back on when i switch heads.
Old May 17, 2008 | 10:16 AM
joetdk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkb18 &raquo;</TD></TR><TR><TD CLASS="quote">How much boost and what map sensor are you running?</TD></TR></TABLE>
oe map and for the boost im not sure the car was boosted beofre i bought and then when i bought they slod the turbo
the car had a blown head gasket and so i changed that that they took the cel bulb out so i think they had the cel the whole time and were tired of seeing the light lol
and i need it gone i need to smog to
and i was thinking about taking the bulb out beofre i go to smog but they put the car on pre ingition to make sure all bulbs light up
gay and i need this car smoged asap
ummm i also tried another oe map and got the same code too brand new spark plugs brand new coil
Old May 17, 2008 | 10:17 AM
joetdk's Avatar
Default Re: 98 integra gsr cel code p0108 problem help (faejai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by faejai &raquo;</TD></TR><TR><TD CLASS="quote">hope u find out the problem i had the same code + missfire on all 4 cylinders, changed spark plugs,wires, cap n rotor, map sensor, tps, still throwing same codes. until i had ref ticket n had to switch out my itr head + sk2 im and sk cams to stock gsr head, everything went away... hope it doesnt come back on when i switch heads. </TD></TR></TABLE>
yea i had sk2 mani on also i took it off and put stock mani on think that was the problema dn nope stil got the cel light
come on people i kow some one knows how to get rid of this cel
Old May 17, 2008 | 02:16 PM
blkb18's Avatar
The stock map sensor is only good up to a certain ammount of boost, somewhere around 8 or 9 psi. If your over that, maybe thats your problem.
Old May 17, 2008 | 09:39 PM
joetdk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkb18 &raquo;</TD></TR><TR><TD CLASS="quote">The stock map sensor is only good up to a certain ammount of boost, somewhere around 8 or 9 psi. If your over that, maybe thats your problem.</TD></TR></TABLE>
well im not boosted any more should i just buy an oe map or should i buy an aftermarket map and where could i get either one
but i have put a working oe map on the car since the cel was on and turbo was off and it didnt change any thing and the oe map that was on the car beofre i tested the other i tried on my friends car and it worked perfect to and didnt get any cel with the map i had when i had the cel
hope it makes sence kinda confusing lol ^^^^
Old May 20, 2008 | 09:46 PM
joetdk's Avatar
ttt
Spoolup98
Honda CR-V & Element
May 18, 2019 03:21 PM
cgoldman11
Jul 7, 2012 06:37 PM
el_dave_o
Aug 20, 2005 07:10 AM
1strdtko
Mar 4, 2003 04:16 PM
