98 bumper problem
Old Dec 10, 2005 | 10:48 PM
suzawa94's Avatar
Default 98 bumper problem
just got done with the 98 conv, but having an alignment issue. both sides of the bumper seem to "bow" out. in other words, there is a 3/4 to 1/2 inch gap between fender liner and bumper. hence having a "bowed" or "flared" out appearance. the bumper is a brand new genuine OEM.
i think it's the way i stored it. although i did not put any weight on it. basically, i just stood it up. did anybody run into this problem? any suggestions? thanks. this was REALLY disappointing.
Modified by suzawa94 at 10:07 PM 12/10/2005
Old Dec 10, 2005 | 11:00 PM
mattcivic's Avatar
Default Re: 98 bumper problem (suzawa94)
as hard as i tried i could never make body lines match up i always just had my buddy who owns a boddy shop do it
Old Dec 10, 2005 | 11:05 PM
Deluzional's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suzawa94 &raquo;</TD></TR><TR><TD CLASS="quote">
the bumper is a brand new OEM version.
so youre saying OEM style?
Old Dec 10, 2005 | 11:06 PM
suzawa94's Avatar
Default Re: 98 bumper problem (Deluzional)
no, it's genuine OEM.
Old Dec 10, 2005 | 11:18 PM
Deluzional's Avatar
Is the bumper screwed to the fender? Mine use to sag with about a 3/4 gap on one side
Old Dec 10, 2005 | 11:25 PM
suzawa94's Avatar
actually, bumper to fender is flush. from that part it seems to flare out so there is a gap from the fender liner and bumper.
Old Dec 11, 2005 | 09:52 AM
suzawa94's Avatar
i was told to use heat to re-shape back to form. any other suggestions?
Old Dec 11, 2005 | 12:08 PM
mattcivic's Avatar
take it to a body shop
Old Dec 11, 2005 | 12:11 PM
Code Blue's Avatar
Default Re: 98 bumper problem (mattcivic)
are you guys kidding me? take it to a body shop?
did you swap the fender liners over??
the 94-97 fender liners are different than the 98+ fender liners.
Old Dec 11, 2005 | 01:06 PM
mattcivic's Avatar
Default Re: 98 bumper problem (Code Blue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Code Blue &raquo;</TD></TR><TR><TD CLASS="quote">are you guys kidding me? take it to a body shop?
the 94-97 fender liners are different than the 98+ fender liners.</TD></TR></TABLE>
guys? im the only one saying that so bitch at me. im just not good at **** like that and i get it done hella cheap when i need it done but i havent done body mods in so long it doesnt matter.
Old Dec 11, 2005 | 02:02 PM
bg-33p's Avatar
i did a 98+ front bumper conversion on my 94-97 and mines does the same, so yes i suggeset u take it to a shop to get it "perfectly" aligned
Old Dec 11, 2005 | 06:22 PM
suzawa94's Avatar
Default Re: 98 bumper problem (teggysue)
thanks for all the replies and suggestions. i found the problem. my corner brackets were to blame. the part on the bracket where the tab goes in was stiff causing the light to push out and in turn causing the ends to flare out.
Old Dec 11, 2005 | 07:10 PM
Code Blue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suzawa94 &raquo;</TD></TR><TR><TD CLASS="quote">thanks for all the replies and suggestions. i found the problem. my corner brackets were to blame. the part on the bracket where the tab goes in was stiff causing the light to push out and in turn causing the ends to flare out. </TD></TR></TABLE>
bonus.
Greg50Lt
Honda Civic (2006 - 2015)
13
Aug 19, 2007 03:07 PM
chris215chris
Jul 12, 2003 06:54 PM
TurbothisLS
May 28, 2003 05:07 PM
smeister
Dec 9, 2002 01:47 PM
