94 Integra HELP!!!!
Old Jan 14, 2009 | 08:59 PM
vche101's Avatar
Default 94 Integra HELP!!!!
Hi Guys,
I'm new to the forum and to Acura. I picked up a 94 Integra and im trying to figure out couple of things. So far, from what i researched i figured out that it has a GSR B18C1 block, B16 head (stamped 89), and 2000 civic intake manifold. So here is my problem... the guy that i bought it from had it wired up by ls engine harness and i just bought a gsr harness and in process of wiring it up but i have couple of extra plugs from the harness which i have no clue where it plugs in to. Is this a right set up(block, head, manifold)? any help would be greatly appriciated. Thanks ahead.
Old Jan 15, 2009 | 05:04 AM
vche101's Avatar
Default Re: 94 Integra HELP!!!!
bump
Old Jan 15, 2009 | 06:01 AM
neardon's Avatar
I'm a Jackass
Your setup works together fine, in fact if you put different pistons and cams in you could have a "poor mans type-r". Did you make sure all the sensor on the block, head, and manifold are plugged in? If you did then you should be good, if anything you will get a CEL and it will tell you what sensor is missing.
Old Jan 15, 2009 | 10:42 AM
halocore's Avatar
the gsr harness might have a couple of extra plugs such as the IAB that you won't use. but other then that your should be fine
Old Jan 15, 2009 | 02:48 PM
vche101's Avatar
what is a CEL?
Old Jan 15, 2009 | 02:58 PM
mrdeadman's Avatar
They let me pick
check engine light.
Old Jan 15, 2009 | 02:59 PM
vche101's Avatar
that's exactly what I'm trying to figure out. do you know what are the Other plugs that I don't plug in and if I don't plug it in is tht going to give me check engine light? Thanks.
Old Jan 15, 2009 | 03:23 PM
vietnamezerice's Avatar
if you have any questions on any plugs it will help us alot if you had a picture of the plug and the wire colors
dc2lee
Mar 17, 2017 08:40 PM
dansparkeyASE
Aug 5, 2015 05:55 PM
vche101
Jan 15, 2009 03:26 PM
baonest1
Jan 27, 2003 02:26 AM
