94 to 91 conversion
I have a 94 b18b sitten around and my 91 blew up... Is there any problem i will run into while duing this swap... the the obd0 to odb1 **** i am aware of should i just swap the intake mani? if u guys could help me out that would be great
you'll just need to use your 91 distributor. other then that its a direct drop in. other then the map sensor, which MIGHT be on your t/b. you'll just have to extend the wire.
but isnt the 94 a b18a still?
