91 Integra Distributer problems
Old Oct 26, 2007 | 09:41 AM
NonovUrbizniz's Avatar
Loved
Default 91 Integra Distributer problems
Hello all,
Longtime member with a friend who's got a problem with a 91 acura integra.
Not sure on the trim yet.
Just curious if there's a quick link to the testing procedure for the sensors in the distributer. or if someone can give a quick walk through.
His boss' station car broke down and the shop is saying replace the whole dist. for 350 in parts... which seems reciculous to me...
It's almost always one of the sensors or the ICM and usually not a physical problem with the dist...
Any help appreciatted.
Old Oct 26, 2007 | 09:47 AM
St Jimmy's Avatar
* B A N N E D *
Default Re: 91 Integra Distributer problems (NonovUrbizniz)
check the ignitor
http://www.team-integra.net/fo...age=1
Old Oct 26, 2007 | 10:11 AM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: 91 Integra Distributer problems (St Jimmy)
the ignition module and coil can be tested for FREE at your local autozone
Old Oct 26, 2007 | 11:50 AM
Loved
Default Re: 91 Integra Distributer problems (GRAF-FITI)
cars dead at shop... Can't bring to AZ.
Just wondering if anyone had the actual voltages and terminals for the 91 teg.
I'm assuming that the link above has the correct voltages?
Thanks all.
Old Oct 26, 2007 | 11:56 AM
AnDy327's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NonovUrbizniz &raquo;</TD></TR><TR><TD CLASS="quote">
His boss' station car broke down and the shop is saying replace the whole dist. for 350 in parts... which seems reciculous to me... </TD></TR></TABLE>
WOW!! That is rediculous!!
Seeing as you can buy a new one for 150 or cheaper off ebay.
Old Oct 26, 2007 | 12:00 PM
GRAF-FITI's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NonovUrbizniz &raquo;</TD></TR><TR><TD CLASS="quote">cars dead at shop... Can't bring to AZ </TD></TR></TABLE>
dude its 3 bolts to take the distributor off
Old Oct 26, 2007 | 12:01 PM
AnDy327's Avatar
Default Re: 91 Integra Distributer problems (AnDy327)
This Should Help You
http://www.team-integra.net/se...=1112
Old Oct 29, 2007 | 12:20 PM
Loved
Dude how are you going to test a distributer when it's not attached to the car??
AnDy327:
Appreciatte the link to the testing procedure.
Old Oct 29, 2007 | 12:43 PM
GRAF-FITI's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NonovUrbizniz &raquo;</TD></TR><TR><TD CLASS="quote">Dude how are you going to test a distributer when it's not attached to the car??
.</TD></TR></TABLE>
man let me make it simple for you: unbolt the distributor, take off your cap and rotor. inside there is a coil and an ignition module. the coil provides the spark and is measured in ohms for resistance. if the resistance is not within the tolerable range, you will get no spark.
the module needs a specific machine to test it. the module controls timing/spark/fuel etc. there are about 7 parameters to test it for, and if it fails even one of those it's shot.
that's how you test the distributor when it's not attached to the ENGINE (as it doesn't attach to the car) only real problem you can have with the distributor body itself is either the bearing seizing or the inner allignment portion the meshes with the camshaft rounding ( rare).
you can go drop your $350 but as a "long time member" you should know better
jdm_soya
Dec 7, 2008 01:37 PM
jimmy o.
Apr 4, 2008 05:28 PM
chadalac1712
Feb 3, 2008 06:53 PM
noebrake
Aug 8, 2007 01:57 AM
