90 integra problem someone please help..!!!!!
Old Jun 7, 2008 | 03:27 PM
Chewy Built !'s Avatar
Default 90 integra problem someone please help..!!!!!
i have an 90 integra and its trowing the code 9??...anyone knows how to fix it or what seems to be the problem?...
Old Jun 7, 2008 | 06:06 PM
Default Re: 90 integra problem someone please help..!!!!! (Chewy Built !)
anyone????
Old Jun 7, 2008 | 06:07 PM
stocker2shocker91's Avatar
I requested a short story for a title.
what is code 9
Old Jun 7, 2008 | 06:27 PM
jpeso23's Avatar
find out what code 9 is first, were not that good mayne...!..lol
Old Jun 7, 2008 | 07:19 PM
LS-V_T_fullrace_EG's Avatar
replace your distributor... its the cylinder position sensor... and im pretty sure its easier and cheaper to just replace the distributor... (find a used one)
Old Jun 7, 2008 | 09:24 PM
GSR44's Avatar
are you sure its code 9 and not code 90? one time i got a code and thought it was 9, but when i checked again it turned out to be 90 which is just your gas tank cap
Old Jun 8, 2008 | 10:18 AM
freshdaily's Avatar
yea first make sure its code 9 and not 90. if it flashes 9 quick times then its 9, if it flashes 9 slow times then its a 90. each long(slow) blink counts as 10 and each short(quick) flash counts as 1.
code 9 = CYP cylinder postion sensor
code 90 = EVAP emission leak (gas)
90 usually comes up when the gas cap is loose or off. ORRR it may have a leak in the line some where. smell for gas.
9 can be fixed by replacing the dizzy. Its much easier to just replace the whole thing then tryin to fix it. try a used one at first, and if it fixes the prob. get a new one!
maiden424
Apr 18, 2013 09:34 PM
Maui Built
Feb 5, 2008 11:57 AM
Vindicator9000
10
Jun 22, 2005 05:44 PM
Scharged2000GsR
Dec 6, 2003 06:51 PM
