90 integra engine problem solved
Old Dec 28, 2009 | 06:02 AM
bcp7272's Avatar
Default 90 integra engine problem solved
I own a 1990 integra that I race on round dirt tracks. During my last race in this car, it started to stumble under a load at high rpms. It felt like it was hitting the rev limit early but I know something else was wrong. This is a list of things that a switch out or cheched:Map,tps,iat,ecm,distributor,timing,fuel pressure, and cylinder pressure. Well after all this it still had the problem. Keep in mind there is no exhaust except the header(manifold) so you can hear when something is wrong. If you blip the throttle you know its not fix right away from the sound. A friend stopped by to do a dye head gasket test. It cheched out fine. He wanted me to check the spray at the injectors. Well after I pulled the first injector he advised me of some car companys that put tiny plastic screens in the top of the injectors. Long story short,they were half clogged. I feel this should be added to the list of things to do at your next tune-up. The car has never felt better. CHECK YOUR INJECTORS SCREENS. I hope this helps someone.
lamesa
Jan 2, 2015 04:06 AM
2ndchirp
Nov 4, 2008 09:57 AM
Nashville
12
Jan 22, 2008 09:55 AM
b20accord
Feb 8, 2007 10:33 PM
