90 integra build
Old Dec 27, 2008 | 04:28 PM
cdrift's Avatar
Default 90 integra build
Just purchased this integra, then I start having problems, but there is light at the end of the tunnel.
got new valves and a good head cleaning
Old Dec 27, 2008 | 04:45 PM
majinsoftware's Avatar
Default Re: 90 integra build
Ouch that valve looks wasted.
How was the piston and the port?
Old Dec 27, 2008 | 04:47 PM
cdrift's Avatar
200 and the head looks brand newThe pistons were fine through. New valves were another 200
Old Dec 27, 2008 | 07:58 PM
Guess you came out quite lucky then. Could of been alot worse.
Id give the head a port and polish aswell as a slight skim while its off.
Old Dec 27, 2008 | 10:51 PM
cdrift's Avatar
if I knew how to port & polish it myself I would, just installing the valves was expensive enough for my budget.
car 2000 (wasn't broken when I bought it)
valves 200
valve job 200
head gasket set 140
manual 15
timing belt 60
still need to buy oil, antifreeze, power steering belt and booze for my mechanic
everything is adding up with this car and since these costs came all of a sudden I just want this car running reliably so I can get to work and not worry about it breaking down. At least the car will be running in peak performance. I am also wondering if I should change the fuel filter since it was the valves that failed, looks like due to deposits.
Old Dec 28, 2008 | 12:57 AM
You could get a little dye grinder/dremial with a sanding head and just sand away all the carbon build up.
Wont give you massive gains but it will atleast get you back to stock flow, especially on the exhaust side.
I did mine with a little wire wheel and a drill lol.
But only on the exhaust side because it gets alot of carbon build up because my car has to run really rich at idle.
Also with the valve like that I would be looking at replacing a O2 sensor.
Old Dec 31, 2008 | 02:53 PM
cdrift's Avatar
well car is finally running again and I hope that is the last of that problem.
"Also with the valve like that I would be looking at replacing a O2 sensor. "
would a faulty o2 sensor cause such valve buildup?
RACEPAK
Jul 23, 2011 03:59 PM
lwmmuas
Feb 3, 2010 09:09 AM
DJYoshaBYD
Dec 9, 2009 10:59 AM
jdmjeff
Dec 21, 2005 02:18 PM
Integra91LS
Feb 28, 2002 02:16 PM
