80mph drop down
Old May 10, 2006 | 05:02 AM
DA is best's Avatar
Default 80mph drop down
what gear and rpm are you guys at when you drop it down at 80 mph because i have a b18a with ys1 tranny and i would like to drop it down to 3rd but i cant so i get smoked alot because my 4th gear dont have no power, but then again im only runnin intake right now do you guys think that header and full exhaust would help my 4th gear
Old May 10, 2006 | 05:09 AM
numbnuts22715's Avatar
it should help it a little bit.
I drop down to third, but I have a 99 gsr. so its a little different.
Old May 10, 2006 | 05:59 AM
[ iLL ] iNt3GrA's Avatar
Default Re: (numbnuts22715)
you have an ls with an intake.... u are going to get smoked
Old May 10, 2006 | 07:33 AM
loudassVTEC's Avatar
Default Re: ([ iLL ] iNt3GrA)
When I drop down to 3rd gear @80mph, I usually tack somewhere around 7800-8000rpms. I have a b16 tranny though, revving to 8400, so I can drop to third at 85 mph if I wanted.
Old May 10, 2006 | 07:55 AM
1337whp's Avatar
Default Re: (loudassVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loudassVTEC &raquo;</TD></TR><TR><TD CLASS="quote">When I drop down to 3rd gear @80mph, I usually tack somewhere around 7800-8000rpms.</TD></TR></TABLE>
maybe a little under that rpm but pretty much same
Old May 10, 2006 | 07:57 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
Default Re: (1337whp)
yeah im right there with you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1337whp &raquo;</TD></TR><TR><TD CLASS="quote">
maybe a little under that rpm but pretty much same</TD></TR></TABLE>
Old May 11, 2006 | 08:31 PM
Default Re: (SupersonicBlueGSR)
I'm running the b16 cable trans that has the 4.4 final drive. It's out of the 90-91 XSi. I know that some had a little bit longer gears, so that maybe why.
Old May 11, 2006 | 09:52 PM
Sack Master's Avatar
Give that baby some love(and some boost) and you won't have to drop into 3rd on the freeway going 80mph just to pass a lincoln
Old May 12, 2006 | 04:45 AM
Robstunner4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [ iLL &raquo;</TD></TR><TR><TD CLASS="quote"> iNt3GrA]you have an ls with an intake.... u are going to get smoked</TD></TR></TABLE>
lol
Old May 12, 2006 | 04:57 AM
InfamousDC2FI's Avatar
Default Re: (Robstunner4)
omg.......is this guy serious?? Yeah go get a header and exhaust cause it will help 4th gear pull that much better....
Old May 12, 2006 | 05:12 AM
DA is best's Avatar
yeah im ordering h/e this weekend, and im scared to go turbo because my engine has 235,000 miles on it
Old May 12, 2006 | 06:14 AM
HONDA RR's Avatar
Default Re: (derek21)
I drop down to third on my gsr when doing 80mph and it works fine.
Old May 12, 2006 | 08:35 AM
Jdmdc4ls's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by derek21 &raquo;</TD></TR><TR><TD CLASS="quote">yeah im ordering h/e this weekend, and im scared to go turbo because my engine has 235,000 miles on it</TD></TR></TABLE>
drop it down to second and ur stock turbo will kick in. . u can drop it to third but theres no point. fourth should be ok.
Old May 12, 2006 | 12:54 PM
Default Re: (jdmdc4ls)
i hit vtec in reverse. its tight
Old May 12, 2006 | 12:55 PM
teggy182's Avatar
/\seen him do it. its mega jdm
Default Re: (teggy182)
its integrathreadhondateckeriffic
Old May 12, 2006 | 01:40 PM
Tornadom's Avatar
An engine rebuild will help your 4th gear pull. You will gain more power by freshening up your motor, than any of the basic bolt-ons will get you. What are you trying to accomplish?
Old May 12, 2006 | 04:13 PM
Default Re: (Tornadom)
hes prob trying to prove something on the street to his buddys........dude get it through your head....upgrading h/e on a motor with 235,000 is almost going backwards. Say you spend around $500 for a cheap header and exhaust.....you could easily get a new b18a shortblock for 700 shipped and have a fresh motor to work with....
Old May 16, 2006 | 09:44 AM
DA is best's Avatar
thats what im savin my money up for right now is a new motor
Old May 16, 2006 | 09:46 AM
DA is best's Avatar
i want to get and build the new motor quick before my motor dies because i got water in my intake and it bogs down at low rpm
Old May 16, 2006 | 10:23 AM
aquabob89's Avatar
* B A N N E D *
Default Re: 80mph drop down (derek21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by derek21 &raquo;</TD></TR><TR><TD CLASS="quote">i want to get and build the new motor quick before my motor dies because i got water in my intake and it bogs down at low rpm</TD></TR></TABLE>
Water in your intake is pathetic. Fix that junk. Its probally your headgasket.
Dont race your motor if you want it to last any longer than it has. I bet its on its last leg as it is.
Old May 16, 2006 | 10:42 AM
benjaminenjamin's Avatar
Default Re: 80mph drop down (aquabob89)
i have a question? why are you starting a race at 80 mph in your stock LS? do you have any suspension work done? if not, i dont suggest you go too much faster in your 15 year old car with 235K on it. not trying to be a smart ***, but the stability of your car should be considered too.
Old May 16, 2006 | 11:25 AM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by derek21 &raquo;</TD></TR><TR><TD CLASS="quote">what gear and rpm are you guys at when you drop it down at 80 mph because i have a b18a with ys1 tranny and i would like to drop it down to 3rd but i cant so i get smoked alot because my 4th gear dont have no power, but then again im only runnin intake right now do you guys think that header and full exhaust would help my 4th gear </TD></TR></TABLE>
on my ls with a A1 tranny i could drop into 80 and then hit limiter at 85.
my b16 tranny on my ls i would have to drop into 4th because my 3rd topped at 80.
with my poormans ITR with my b16 tranny i can drop at 80 and ride it up to about 94/95....i rev to 8600 though.
to that comment about a ls with intake is gonna get smoke...i laugh at that, and say it just depends on the ls and the weight of the car.
Old May 16, 2006 | 11:30 AM
1337whp's Avatar
Default Re: 80mph drop down (projectTeG)
maad 3rd gear pull yo vtak
Old May 16, 2006 | 05:13 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">
to that comment about a ls with intake is gonna get smoke...i laugh at that, and say it just depends on the ls and the weight of the car.</TD></TR></TABLE>
I laughed too. People really do underestimate the LS. I handed a lot of people their asses with my LS. I wish I would have never gone with a b16. I should have done headwork and some cams, and made 170whp, instead of 145 with the b16.
