5 lug conversion
Old Nov 17, 2007 | 11:14 AM
soon2bdropped's Avatar
Default 5 lug conversion
Sup guys well I got a 94 gsr with 4 lug, I can get the 5 lug conversion off a type r, what all will I need front and back... I just need da knuckles right. My front lower control arm and rear of my gsr should still work.. Wat about da rear shocks and rear swaybar I heard is different. Basicially can I put my old 4 lug and suspensiom from my gsr back into the type r will it fit...
Old Nov 17, 2007 | 01:01 PM
Default Re: 5 lug conversion (soon2bdropped)
Come on I'm pretty sure somebody did this conversion before.
Old Nov 17, 2007 | 02:13 PM
omnirage's Avatar
^ So why not search?
Old Nov 17, 2007 | 02:20 PM
BlueIntegraBoy's Avatar
Default Re: 5 lug conversion (omnirage)
1. Front knuckles with everything on it.
2. Rear trailing arms with everything on it.
Optional:
1. rear LCAs with struts
2. rear sway bar (you'll need an ASR brace, BSQ kit, or Beaks kits to prevent subframe tear out)
Old Nov 22, 2007 | 12:38 AM
Default Re: 5 lug conversion (BlueIntegraBoy)
Yo what's up well can I still use my old gsr rear swaybar or it won't work due to the different lower control arms?
Old Nov 22, 2007 | 12:44 AM
Naruto's Avatar
no.....like he said with the optionals.....2. rear sway bar (you'll need an ASR brace, BSQ kit, or Beaks kits to prevent subframe tear out).
This was if you decided to use the ITR rear lower control arms, and use the itr rear sway bar. Otherwise, just swapping out the rear trailing arms with the hubs will do just fine.
Jdm-Beast
Suspension & Brakes
1119
Jul 27, 2015 09:28 AM
Ra GS-R
Aug 1, 2007 02:38 PM
kcjohnnyboy
Suspension & Brakes
Jun 21, 2005 10:22 PM
daddymax
Sep 20, 2003 08:39 AM
SPOONfdEK
Aug 16, 2003 04:23 AM
