4dr and 2dr axleback difference?
Old Feb 3, 2011 | 02:15 AM
teamjdm239's Avatar
Default 4dr and 2dr axleback difference?
is there any difference in length/degree in the 2dr axleback exhaust, or the 4dr? or are they exactly the same, and its the mid-pipe that makes it longer? in other words im trying to use a 4dr axleback with my coupe mid-pipe.. will it fit like normal?
Old Feb 3, 2011 | 03:05 AM
N/A's Avatar
N/A
Purpose Built
Default Re: 4dr and 2dr axleback difference?
Yea
Old Feb 3, 2011 | 07:22 AM
teamjdm239's Avatar
Originally Posted by N/A
Yea
yea what?
Old Feb 3, 2011 | 09:03 AM
CleanLikeJdm's Avatar
Hype-R Stalker
It should be longer, so it will probably be pushed against the bumper.
I've used 2dr axlebacks on my 4dr, and the muffler tip will be even with the bottom of the bumper.
Old Feb 3, 2011 | 11:29 AM
Bowl_of_Rice's Avatar
the mide pipe is the same its just the axleback on the four door behind the muffler is extended by like 2 inches i think
Old Feb 3, 2011 | 12:55 PM
JdmTypeRdc2's Avatar
The 2dr axleback is shorter making it a flush and tighter fit on a 4dr.
Old Feb 4, 2011 | 11:29 AM
No-Gi's Avatar
can a 2 door catback be modified to fit a 4 door?
Old Feb 4, 2011 | 12:09 PM
N/A's Avatar
N/A
Purpose Built
THEY WORK, JUST PUT IT ON
Old Feb 4, 2011 | 03:21 PM
happyc4mp3r's Avatar
im pretty sure they work
Old Feb 4, 2011 | 06:37 PM
fonkernuckle's Avatar
yeah they will work but you will find that the rubber pieces that hold the axelback will be stretched rearward when the 4dr axelback is put on the 2 dr one and the muffler will be up tight against the body and it will "rattle". I did this months ago until I found a coupe one for cheap. The rattle got very annoying.
Old Feb 12, 2011 | 10:10 AM
EnjoyTheRideDC2's Avatar
The Sedan muffler tip section is 4 inches longer than the Coupe.
So if you throw a DB axle back section on a DC, your exhaust tip will stick out from the rear bumper instead of being flush with the end of the bumper.
A DC axle back section on a DB will result in the exhaust tip being tucked behind the bumper. The tip wont even stick out from the bumper opening,.
Old Feb 12, 2011 | 02:14 PM
SiLEnT_ST's Avatar
He's right. I have a dc2 non brand axleback exhaust on my db8 and the back exhaust is tucked in behind the bumper. But then i have an accord mid pipe on mine though. So not sure if it'll make a different.
Old Feb 12, 2011 | 06:07 PM
Makes no difference....Although i'm curious how well the Accord mid-pipe fits on a DB...?
Old Feb 12, 2011 | 06:20 PM
senser1080's Avatar
Just about two inches.
Old Feb 13, 2011 | 12:52 AM
Its actually 4 inches....
Old Feb 13, 2011 | 12:58 AM
N/A's Avatar
N/A
Purpose Built
I got a greddy muff for sale op!
Old Feb 13, 2011 | 09:25 AM
94 ls-r's Avatar
My 4 door I just bought has a extension behind the cat that the other guy welded in to make fit. Still little short tho
Old Feb 13, 2011 | 12:58 PM
SiLEnT_ST's Avatar
I never did measure mine so im not sure. but may be it is 4 inches longer. For the back it'll be the same but at the front it'll go past where the cat is at so you'll have to cut the piping or the header. On mine the previous owner cut the header so now im stuck with a f'ed up pipping, i cant fit any other headers on at all.
LickyMYwalker
Aug 6, 2008 10:47 PM
RP215.
Jul 6, 2006 08:48 PM
digitalspice
Nov 3, 2002 12:52 AM
Cow
Jan 10, 2002 09:31 AM
1fastGSR
Dec 15, 2001 03:12 PM
