4 wheel disc conversion
Old Jul 6, 2003 | 09:05 PM
b16hybridsol's Avatar
Default 4 wheel disc conversion
i have a 90 civic hatch and i took the rear disc off of a 93 acura integra. Now that i have all that done i had no pressure and i bled the brakes and i got some pressure but when i started the car all the pressure went away so then i replaced master cylinder, power brake unit, pads. rotors. then i bled the brakes again and the same thing happened i got pressure and then i started the car and lot all the pressure. ive checked for leaks and there are none i dont know what else to do.
Old Jul 6, 2003 | 09:12 PM
romeo619romeo's Avatar
Default Re: 4 wheel disc conversion (b16hybridsol)
make sure you bleed with the car on
Old Jul 6, 2003 | 09:25 PM
90LSVTEC1's Avatar
Default Re: 4 wheel disc conversion (romeo619romeo)
i dont see what bellding with te car on would do bleeding just gets air out of the lines u dont get air in the lines from turning the car on the only place the u get air from the motor is in the power brake unit
Old Jul 6, 2003 | 09:38 PM
CoryTurner's Avatar
take the top off the master cylinder so the air has someplace to escape to.
Old Jul 6, 2003 | 11:34 PM
Default Re: (CoryTurner)
ive already done that doesnt work
Old Jul 6, 2003 | 11:40 PM
SPOON DC2's Avatar
sorry, not sure good luck! <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16hybridsol &raquo;</TD></TR><TR><TD CLASS="quote">i have a 90 civic hatch and i took the rear disc off of a 93 acura integra. Now that i have all that done i had no pressure and i bled the brakes and i got some pressure but when i started the car all the pressure went away so then i replaced master cylinder, power brake unit, pads. rotors. then i bled the brakes again and the same thing happened i got pressure and then i started the car and lot all the pressure. ive checked for leaks and there are none i dont know what else to do.</TD></TR></TABLE>
blaze_125
28
Feb 17, 2011 07:54 AM
ThaSpitefulWun
Nov 17, 2004 06:34 PM
b16hybridsol
Jul 6, 2003 11:39 PM
memphiss13
11
Mar 7, 2003 10:40 AM
Asahi
Apr 3, 2002 03:59 AM
