2 questions
Old Feb 3, 2003 | 02:35 PM
Brasspremier's Avatar
Default 2 questions
1st one is simple enough. whats good way to get rid of stickers that are on the car? there is sticker on it from original owner meant for like a parking pass of some kind, and i'm not gonna use the pass so want to get rid of it. whats best way?
and secondly, i was just looking at my car today and noticed that my car looked strange... the front left side looked low... i checked all the tire pressures and they were all good. i pulled out a ruler and meassured from top of wheel well to top of tire and the front left was .5 lower than the rest. whats up? stock springs and shocks and car has bout 100,000 miles, think its bad springs or shocks? if so, good reason to get new stuff sooner than later
Old Feb 3, 2003 | 02:37 PM
threatcon13's Avatar
New User
Default Re: 2 questions (Brasspremier)
1. razor alone..or razor and googone. I'm not sure about #2...it might come .5 inch lower in the front from the factory..if not though..replace springs/struts...
Old Feb 3, 2003 | 02:38 PM
zilverz's Avatar
Well if the alignment doesnt FEEL fragged when you drive it .. id say yea bad shock/strut
Old Feb 3, 2003 | 02:42 PM
Default Re: 2 questions (zilverz)
and when i mean .5 inches, more closer to .75
Old Feb 3, 2003 | 02:49 PM
Heres pic of lower one
and of normal one
Old Feb 3, 2003 | 03:02 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: 2 questions (jasonk)
Unless you are using the razor on glass, don't use a razor on your body panels. You'll cut into the paint. Try using a hair dryer to heat up the sticker and try to peel it up from an edge. Or, I think 3M make something to take adhesives off.
Old Feb 3, 2003 | 03:03 PM
Default Re: 2 questions (Gee3)
ya, its on body panel
Old Feb 3, 2003 | 03:20 PM
i tired the blow dryer idea and didnt do much
Old Feb 3, 2003 | 03:33 PM
Supadave's Avatar
Does it look like the shock is leaking at all?
Old Feb 3, 2003 | 03:36 PM
IN VTEC's Avatar
.5" lower than the rest
That's normal...unless you don't drive on that side of the car.
Old Feb 3, 2003 | 03:47 PM
Default Re: 2 questions (IN VTEC)
well, i wasnt in the car when i was meassuring it now was i
Old Feb 3, 2003 | 05:06 PM
IN VTEC's Avatar
No, but the springs tend to stay that way after a while.
Old Feb 3, 2003 | 05:34 PM
B2FiNiTY's Avatar
100k miles...should be time to change them anyways.
xXBlack OpsXx
Aug 8, 2011 01:10 AM
matteeeee
Apr 9, 2007 07:35 AM
Didly
Suspension & Brakes
10
Mar 14, 2006 11:52 AM
eymnewdc4
Dec 2, 2004 11:28 AM
