1990 integra strut
Old Jun 14, 2010 | 05:53 PM
cheddarbob41's Avatar
Default 1990 integra strut
So i did some research and found that the EF struts/coilovers will fit a DA. So i got these struts off a 91 civic hatch to go on my DA, and they are not fitting into the control arm on the front side of course. So my question is are they suppose to fit or do i need EF control arms or am i doing something wrong or are they not really off an EF? Thanks!
Old Jun 14, 2010 | 06:05 PM
EHondaJDM's Avatar
Default Re: 1990 integra strut
think of the difference in weight between the vehicles
Old Jun 14, 2010 | 06:20 PM
Oh you mean the 435 lbs difference? I'm not really asking about all that, and that doesn't really answer any of my questions at all thanks tho. Should the EF strut bottom slide right into the control arm or does it need to open up more.
Old Jun 14, 2010 | 06:26 PM
EHondaJDM's Avatar
itll probly fit but the teg springs r bigger cause the weight
Old Jun 14, 2010 | 06:38 PM
Oh and I guess I shoulda mentioned they're not stock components coming off the ef....they were just on the ef
Old Jun 14, 2010 | 07:03 PM
90_EX_Civic's Avatar
they should, with no problem.
check to see if your control arm isn't bent, or the forks for the struts aren't bent, which if it is, is a cheap fix.
Old Jun 14, 2010 | 07:13 PM
yeah i mean the forks dont seem bent at all but i put the it in the top but the round bottom wouldnt go in. So i took it out and tried still a no go. Measured em it seems to be ever so slightly larger diameter but the guy i got em from swears they are off a 91 hatch so idk. I might just put the springs and coil on the original struts.
Like the control arm shouldnt have to expand at all right?
Old Jun 14, 2010 | 07:31 PM
EHondaJDM's Avatar
dont go shootin yourself in the leg while doin it
Old Jun 14, 2010 | 07:38 PM
for cheddarbob reference
Old Jun 14, 2010 | 07:39 PM
EHondaJDM's Avatar
had to
should fit tho man try re positioning it
Old Jun 14, 2010 | 07:40 PM
I have both the components off the car trying to put them together and they still won't fit. Oh well I am done for the night anyways...maybe tomorrow they will magically fit.
Old Jun 14, 2010 | 07:42 PM
EHondaJDM's Avatar
Black R
Suspension & Brakes
14
Aug 31, 2010 08:51 PM
ef_hondas
Feb 4, 2010 04:37 PM
EF'n Stig
Aug 6, 2006 06:56 PM
