1990 integra power window conversion
Old May 30, 2011 | 05:22 PM
qpzm12's Avatar
Default 1990 integra power window conversion
i went to junkyard today and bought complete power doors off of a 1992 integra i believe.. i pulled out complete wiring harness off of the car that goes from door to door and to under dash fuse box. i came home installed everything except now i dont know where to plug in 3 plugs that came out of the fuse box. they are ... one pin plug, black/yellow... 2 pin plug yellow/red & black .... and a 4 pin plug that only has 2 wires... white/yellow & yellow/red . i know people have done this and ive been looking but cant find anyone that has had this problem. any help??
Old May 31, 2011 | 05:57 AM
fcm's Avatar
fcm
Old Fart
Default Re: 1990 integra power window conversion
What is not working? 94
Old May 31, 2011 | 10:20 AM
qpzm12's Avatar
the windows are not working the up and down switch the power mirrors dont work.. they look like power wires. i read this somewhere
The white/yellow goes to fuse 7 - 20A and comes from drivers window switch.
The blue/black goes to fuse 2 - 20A and comes from both the drivers door pass. window switch and the pass. door window switch.
There is also a black wire from drivers door pass. window switch, [up] that runs to and connects to pass. switches blue/yellow and another black wire from drivers door pass. window switch, [down] and connects to pass. switches blue/green.
the wires missing that i have no where to plug in
PLUG#1=BLACK/ YELLOW
PLUG#2=BLACK/YELLOW+YELLOW/RED
PLUG#3=BLUE/BLACK+WHITE/YELLOW
Old May 31, 2011 | 01:40 PM
fcm's Avatar
fcm
Old Fart
White/yellow is power for drivers window, [drivers window switch] and should go the fuse 7.
Blue/black is power for pass. window, [pass. switch in drivers door and pass. switch and should go to fuse 2.
The two black leads are reversed, the black on drivers door pass switch down goes to the pass. door switch, blue/yellow, the up goes to the blue/green.
Did you do power locks also?
Did you get the power window relay, [plugs into under dash fuse box]?
Did you install a 20A fuse in fuse location 16, [fuse for power window relay] on under dash fuse box?
Sorry I do not have a diagram for power mirrors...
The black/yellow is normally an ign. 1 power lead, [hot when ign. switch is in run or start], the only yellow/black for power windows would be the power for right rear switch power window switch in both drivers door and right rear door switch, if yours is a 2 door then it does not exist, it could be power for the power mirrors. 94
Old May 31, 2011 | 07:45 PM
qpzm12's Avatar
i go the windows working today ... out of the % wires i simply connected blue/black wire & white yellow to power and the windows worked. i did not get power locks. so not my question is i know the blue and yellow wire need to go to fuse 7 and 2 ...how do i do this?? i did not get a power window relay
Old Jun 1, 2011 | 05:33 AM
fcm's Avatar
fcm
Old Fart
The power window relay is what supplies power to fuse 2 and 7, it is done internaly in the fuse box.
Are the blue/black and white/yellow leads not in a plug that plugs into the fuse box?94
Old Jun 1, 2011 | 08:44 PM
qpzm12's Avatar
they are not plugged into no plug they are spliced and just ran to a power source
Old Jun 2, 2011 | 05:37 AM
fcm's Avatar
fcm
Old Fart
They need to be fused. 94
Old Jun 2, 2011 | 09:35 PM
qpzm12's Avatar
how can i run the correctly to the fuse box?
Old Jun 3, 2011 | 05:29 AM
fcm's Avatar
fcm
Old Fart
You need to find the correct plug to plug them into, look for plugs with missing wires, install fuses in locations 2 and 7, use a test light in the empty plug pin locations untill you find one with power when ign. switch is on, then remove fuse 2 or 7 to see if the pin location you have is related to one of those fuses, keep testing untill you find pin locations for both fuses.
Keep in mind you must have the power window relay installed and fuse 16 -20A installed for there to be power at fuse 2 and 7. 94
pldwelle
Sep 22, 2010 08:39 PM
eg6sir88
Mar 24, 2010 06:25 PM
dc4teg95
Sep 1, 2009 12:26 PM
gmadsen100
Jul 10, 2009 06:07 AM
aktc167
May 10, 2005 07:33 PM
