1' cut in tire
Old Jun 5, 2007 | 06:23 PM
team714's Avatar
Default 1' cut in tire
theres a 1' cut in my rear tire. its about a 1' long and looks like a 1' deep. brand new tire about less than 20,000 miles on it. should i be worry about the cut getting bigger as i drive?
Old Jun 5, 2007 | 06:51 PM
numbnuts22715's Avatar
I guess you actually mean 1 inch long and 1 inch deep?
if its 1 ft deep thatd be all the way through.
Even if it was 1 inch deep itd be pretty much all the way through....
is it just like a tiny little slit in the tread? or what?
Old Jun 5, 2007 | 07:10 PM
team714's Avatar
Default Re: 1' cut in tire (team714)
yea its where the tire tread and outside part of the tire meet.
Old Jun 5, 2007 | 07:59 PM
forumnoobie's Avatar
I would not compromise my safety for one tire. Not worth the hassle when it blows out on you.
Old Jun 5, 2007 | 08:32 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: 1' cut in tire (forumnoobie)
One inch is deeper than the thickness of a tire all the way through.
If you have a big gouge in the place where the sidewall meets the tread, the tire should be discarded. It's unsafe.
You can take it to your local tire shop. They will tell you the same thing.
If it's just a tiny chunk of rubber, though, it might not be a big deal.
Got pix?
Old Jun 5, 2007 | 09:03 PM
alexisthemovie's Avatar
around 20,000 miles is not what i would consider "brand new"
Old Jun 6, 2007 | 07:28 AM
team714's Avatar
i ll take pics asap
Old Jun 6, 2007 | 01:17 PM
b18LS's Avatar
Id replace it, even if it didnt effect tire duarbility (which it probably does) it'll bug you whenever your on the highway! especially if it pops! Think of the load your tire sees when you hit a bump. A weak spot is exposed pretty fast.
Old Jun 7, 2007 | 07:46 AM
team714's Avatar
go to this link http://www.we-todd-did-racing.com/public/view/6569
let me know guys thanks
citrus3000psi
May 26, 2008 08:29 PM
iixerOii
Mar 25, 2005 07:05 AM
erikiksaz1
Sep 5, 2004 10:14 PM
gsr94
Jun 24, 2002 03:41 PM
