00 teg coilover help
Old Dec 11, 2005 | 01:04 AM
aznteg's Avatar
Default 00 teg coilover help
ok... got some tenzo r coilover. its for 1-4.5 drop but i just put the frotn 2 on and its like a 3inch raise. even if i turn it all the way to the botton it would only give me maybe the stock looks.....so i dont noe wat i did wrong....dont think i did anythin wrong
Old Dec 11, 2005 | 04:42 AM
Backk InTheDA's Avatar
I hate everything
Default Re: 00 teg coilover help (aznteg)
This is a stupid question but, did you perhaps put the coilovers that were ment for the rear on the front?
Old Dec 11, 2005 | 07:27 AM
aznteg's Avatar
Default Re: 00 teg coilover help (BuilttB18C5)
all four are all the same
Old Dec 11, 2005 | 07:43 AM
Vi3tboy's Avatar
can you take pics of it with the wheel off? just to see how you installed them.
Old Dec 11, 2005 | 08:49 AM
aznteg's Avatar
Default Re: (Vi3tboy)
yeah give me a few ( do you know if the the front suppose to be shorter or taller)
Modified by aznteg at 1:00 PM 12/11/2005
Old Dec 11, 2005 | 08:52 AM
Danronian's Avatar
Most sleeve coilovers have all the same spring height but with the stiffer springs for the front. All the way down should be damn low. They must have sent you a wrong part.
Old Dec 11, 2005 | 09:01 AM
aznteg's Avatar
hey how do i insert image? i clicked on "insert image"
Old Dec 11, 2005 | 09:04 AM
aznteg's Avatar
Default Re: (Danronian)
ok sleeve is alil diff... 2 shorter than the other 2. which go to the front? short? tall?
Old Dec 11, 2005 | 10:26 AM
Vi3tboy's Avatar
upload your pics and put the url here.
{img}http://urlgoeshere{/img} use [] [] instead of {} {}
Old Dec 11, 2005 | 09:09 PM
aznteg's Avatar
ok finally figure it out....the dust cover on the shock was sittin on the coilover sleeve and the top of the dust cove was on the cap so basically it wasnt even sittin on the spring.........so there i have to remove the dust cover or cut ir shorter and ended up jus leaving it off. but hope it wont mess with the shock (dirt getting on it)
Old Dec 11, 2005 | 10:34 PM
mystikalstriker's Avatar
how? coilovers for the front won't fit the rear and vice versa. They just won't fit.
Somehow i think ur problem is could be that you bought Tenzo Coilovers.
Old Dec 12, 2005 | 05:34 AM
Vi3tboy's Avatar
you usually dont use the stock dust cover for aftermarket coilovers. you got sleeves no shocks correct?
brndon076
Suspension & Brakes
29
Jan 29, 2011 08:34 PM
proshift
Suspension & Brakes
Jun 28, 2010 09:54 AM
_HANS
Suspension & Brakes
Mar 26, 2008 10:50 PM
3minburnout
Suspension & Brakes
Sep 12, 2006 03:20 PM
mystikteg92
May 12, 2004 05:47 PM
